Thread: Simpe wiring for 2 speed whisperflow
    Sep 2011
    So Cal
    155
    Hello,
    If I just want to simply wiring the 2-speed pump without any automation except for timer to turn it on/off (I'll use the built in toggle switch to switch between lo/hi), do I wire it just like a single speed?
    I want to try if I can run low speed alone first, if not, I'll consider the automation control later.
    Thanks
    35k Gallon, 2 In Piping, Aquarite, KK, Spa, Water Fall.
    Re: Simpe wiring for 2 speed whisperflow
    From the point of view of the timer, everything is wired just like a single speed pump. But the electrical connections inside the motor are just slightly different. There should be a diagram of how to wire the motor on a plate attached to the motor.
    Sep 2011
    So Cal
    155
    Thank You.
