Results 1 to 9 of 9
Thread: Winter Closing Question
    Sep 2011
    Omaha, NE
    95
    I have read a few of the post and still am not quite sure on the right answer. The 60 degrees number..... Does that mean do not cover until the water temp remains below 60 degess or the outside air temp remains below 60 degrees?
    Also, after reading and reading and reading on this forum, I am going to be going with the BBB method. I want to lower my CYA level so I don't have to chlorinate so high ( I had been use pucks). Will the levels drop automatically over the winter months? I will be draining some water below the skimmer and such for winterizing, so I know that will lower the levels some when I refill in the spring.
    and, so you know what I am working with and numbers:
    16X24 oval AGP, Doughboy
    FCL: 8.12
    TCL: 8.44
    pH: 7.5
    TA: 153
    CH: 200 (since I have vinyl, I assume this number is not critical for me?)
    CYA: 116
    Using the ColorQ digital tester
    16X24 Oval Doughboy
    10,000 Gallons~
    Pentair Dynamo .75/1.0 HP pump
    16" Pooline D-400 Sand Filter w/ 6-way valve
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Winter Closing Question
    Welcome to TFP!
    60 degrees refers to the water temperature. If you follow the closing directions on this site, you should have no trouble opening to a clean pool, regardless of your CYA level. It will go down a bit by spring since you are lowering the water level, but likely not really low enough. I wouldn't make any attempt to lower that level now though; just wait and see where you are come spring.
    Sep 2011
    Omaha, NE
    95
    another question I forgot to ask:
    I live in Nebraska, cold, harsh winters. Remains below freezing from Dec - Mar. Can I leave my sand filter outside after removing the multiport valve, drain the water from filter and the cover with a tarp? or, will I need to empty all the sand and bring it inside as well?
    16X24 Oval Doughboy
    10,000 Gallons~
    Jun 2008
    NW MO
    185
    We leave the multi port on and simply leave the filter drain plug off.
    I know it is recommended to wait to cover until water temp is below 60 - that is so that algae doesn't grow. We always cover before it is 60 and although we do have some algae growth it isn't hard to kill in the spring as long as all the debris (leaves, sticks, etc) was removed before covering.
    24ft AGP 52in deep ~13,500 gal
    Hayward Sand Filter 250 lbs
    SWG
    1.5 HP pump
    425 gal stand alone QCA Hot Tub 15-20 yrs old
    Jul 2008
    Solon, Iowa
    170
    We also leave the filter outside with multiport on (drain plug off - multiport set to 'winter' which is basically a setting between settings so handle stays elevated). I cover it with a tarp (but it is under our deck anyway). I do bring the pump, salt cell, solar valving inside. Drain the pool only a little below the skimmer, plug the skimmer faceplate and return, put on the mesh cover, and by spring it has refilled and ready to open.
    15X30 AGP, Lomart beaded liner;
    1.5 HP Sta-Rite pump with 21 inch sand filter (Zeobrite media)
    Mineral Springs (Aquatrol) SWCG, Rigid PVC plumbing, 2 inch
    Four 4X12 Techno-Solis solar panels, rack mounted, Goldline Solar Controller
    Has anyone ever left theirs stairs in the pool over the winter season? Mine are very difficult to remove and am looking for some advice.
    25,000 gal. inground
    vinyl liner
    Hayward sand filter
    Circupool SWG
    22,553
    I turn mine over on their side and leave them in the pool. Make sure there are no sharp points or edges and they won't hurt anything leaving them in there. I take the weights out and store them separately.
    24' x 52" Round AGP. 2hp/╝hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Why do you take the weights out? What are the weights made of? Mine are sand bags.
    vinyl liner
    Hayward sand filter
    Circupool SWG
    22,553
    Mine are inserts that are molded to fit the steps, and while I could leave them in the pool, if I did, I'd have to fish them off the bottom next spring and they are about 4" thick and weigh about 75# each. It's a convenience thing. It's easier to pick them up and set them in the deck box than to fish them out of 60┬║ water at opening.
