Thread: Jandy PDA confusion
    Jandy PDA confusion
    Hello. My parents installed a new heater with a Jandy PDA, and nobody explained to them how to us it. I'm trying to help them, but the manual is missing some info I need. Can someone help me with these questions?
    1. What's the difference between having POOL MODE ON and going to EQUIPMENT ON/OFF and turning on the pool heater and pump?
    2. If I have an automatic program that sets the pump to turn on at a certain time, is that overridden by the POOL MODE? In other words, if I have POOL MODE turned to 82 degrees, will it turn off when it hits 82 or will it turn off at the designated program time to turn off?
    3. What does it mean when it says ENA next to SPA HEATER or POOL HEATER? What's the difference between ENA and ON or OFF?
    Thanks so much!
    Apr 2009
    Burlington, ON, Canada
    344
    Re: Jandy PDA confusion
    Here's the manual...
    http://www.zodiacpoolsystems.com/Produc ... k-PDA.aspx
    At the bottom of the page, click on 'downloads' and then "H0572300.pdf"
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Thanks. Unfortunately, I have the manual already, but it does not answer my questions.
    Feb 2008
    Dallas, TX
    60
    1. No difference.
    2. Temperature controls the heater only, and the heater can only run when the pump is running. So, setting to 82 just means that the heater will run when the water is < 82 and the pump is running. Turning off the pump or having a program that turns off the pump will not affect the heater setting at all.
    3. ENA means enabled. The heater can be:
    OFF: will not come on at all
    ON: heater is running. This will only happen when the pump is on.
    ENA: heater is enabled, but not running because it is not needed. The pump is not running or the water is warm enough. When the water gets below the set point (82 in this case), the heater will come on (if the pump is running).
    The Jandy systems tries to make it easy for you.
    - Set the temperature you want.
    - Program the time you want to run the pump.
    - The system will turn the pump off and on at the given times, and if needed it will turn on the heater while the pump is running.
    The Jandy system has POOL MODE and SPA MODE. If you don't have a spa, then you will always be in pool mode. The system can be in either POOL MODE or SPA MODE but not both. It can also be off.
    POOL MODE means that the valves are set for pool circulation and the POOL temperature determines whether or not to run the heater.
    SPA MODE means that the valves are set for spa circulation and the SPA temperature determines whether or not to run the heater.
    Usually, the SPA temperature is much higher (~100 or whatever your preference is) than the POOL temperature (82 in your case). Having two modes lets you set the two temps for each, separately, and program run times for the two (POOL, SPA) separately.
    31000 Gal IG L-shape w/ spa, Riversand finish (PebbleSheen clone)
    Jandy 60 sq ft DE, 2.5 HP (uprated) Stealth pump, Polaris 280 w/ booster, Jandy PDA PS4 controller
    Thank you!
