Results 1 to 9 of 9
Thread: How often to drain a pool?
    Sep 2011
    Denton, Texas
    38
    Is it necessary to completely drain your pool every few years? I've been told that around here (North Texas) we should drain and refill every 5 years or so. Is this another "old wives tale", or is it legit?
    30,000 gal in-ground, Stonescapes Tahoe Blue, DE filter, Pentair WFE-30 filter pump, Saltwater Generated Chlorine.
    30,415
    Re: How often to drain a pool?
    Old wives tale...disregard it.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Of course if you have hard fill water like I do, eventually the CH will raise so high that it might be necessary to replace at least some of the water.
    Mark
    High CYA and high CH levels are the two reasons to do a lot of water replacement. If those problems never come up, there is no reason to ever change the water. If you do have problems with CYA and/or CH you have the choice between replacing water or getting a reverse osmosis treatment.
    In any case, there is certainly no reason to replace water on a schedule. Only replace water if there is a specific reason why you need to do so.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by mas985
    Just to add that continued use of stabilized chlorine will eventually raise CYA or CH levels too high as well. If you stick with liquid chlorine or a SWG as we would advise here, then yes an old wives tale unless, as mas985 pointed out, you have high CH (aka "Hard") fill water.
    or, what Jason said
    Sep 2011
    Denton, Texas
    38
    Thanks for the info! We do have hard water here in our local supply, but my pool CH level is usually around 280.
    check your CYA, that sucker seems to go up after years. That is the problem i have with my pool. Will require some drain and fill.
    18K in-ground pool, Concrete, DE Filter
    Dec 2010
    San Diego, CA
    1,137
    Quote Originally Posted by vickp85
    Read post #5 of this thread.
    VickP85: Welcome to TFP! Now go to pool school - link on upper right of every page
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by TXFlyGuy
    Sounds like you CH is fine. Are you having any trouble with your pool chemistry...or just checking out this old wives tale? Let us know , we are here to help.
