Page 1 of 4 1234 LastLast
Results 1 to 20 of 78
Thread: Cloudy pool
    Jul 2010
    Longwood, FL
    151
    Cloudy pool
    Problem. Water is cloudy
    Note: My pool is 15K gallon , concrete, Location : Central Florida
    Pump is running since 9/12 till today
    I DONOT have pool vaccume
    History of events:
    9/11 : water was greenish / cloudy
    added algaecid after 1 hour 2 shocks
    clean filer every 4 hours, brush walls/floor
    test at shop , they said wait till it gets clear
    9/12 : Water light green / cloudy
    tested at shop she told me to shock with 2 bags
    Following are the reading on 9/12 evening
    9/13 : Water is blueish / clody
    9/14 : Water is blueish / cludy
    Reading on 9/12 evening @ shop
    Temp : 80"
    Saturation Indx : 0.2
    TDS : 4500
    CYA : 70
    Tot Chlorine : 9
    Free Chlorine: 6
    Ph : 7.6
    Tot Alkalinity: 108
    Adj Alka : 87
    Tot Hardness : 302
    Minerals : 3100
    Let me know if you need more details
    Thanks in advance for help.
    15,000 Plaster IG Pool
    AquaRite SWG, C1750 Catridge filter
    G3 Vaccum, T-100 Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: Cloudy pool
    You have algae. The cloudiness is dead algae.
    It can be solved fairly quickly if you a) get your own proper test kit, b)shock the pool following the directions in Pool School. Pool School is where you need to start.
    I cannot stress the necessity of a proper test kit enough.
    Jul 2010
    Longwood, FL
    151
    Re: Cloudy pool
    Any suggestion on which kit to buy / from where
    Thanks for reply
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: Cloudy pool
    TF100 or Taylor K2006, see comparisons here http://www.troublefreepool.com/pool-...kit_comparison
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jul 2010
    Longwood, FL
    151
    Re: Cloudy pool
    Quote Originally Posted by msgtdan
    I will order one of these, it will take about 4-5 days for this to arrive !!
    Any intermediate solution ?
    30,432
    Re: Cloudy pool
    You will need a pool vacuum.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: Cloudy pool
    An HTH 6-way with dilution testing of the chlorine test, avg of multiple pool store results, best guess using the pool calculator http://www.poolcalculator.com/. None of which are optimal for shocking but can get you started. The TF100 usually comes pretty quick from all reports, Shipping on the east coast is usually 1-2 days. The HTH 6-way is available at Walmart seasonally and is really intended for temporary pools like I currently am using. Pool stores are notoriously bad with their tests. Best guess with the pool calculator is just that, read up in pool school http://www.troublefreepool.com/pool-school/ how to use it, it can be a little tricky the first few times. You enter the size of your pool at the top, the type of pool and TFP near the bottom.
    Dan D
    htownjeeper's Avatar
    Aug 2011
    Nassau Bay, TX
    199
    Re: Cloudy pool
    I'm in Texas and Dave had it to me in 3 days I think. It won't take as long as it says. Especially in Fla.
    22,000 inground Fiberglass
    DE Filter Pentair FNSP 48
    Century Centurion 1.0 HP 1.25 S.F. 3450 RPM
    Aug 2011
    Nassau Bay, TX
    199
    Re: Cloudy pool
    Does everyone agree he should start shocking immediately? And no, I don't mean that pool store stuff! If it was me I'd use the readings as a temporary basis and begin the shock.
    But I'm new too...just saying what I would do.
    Jul 2010
    Longwood, FL
    151
    Re: Cloudy pool
    Sir what do you mean by "shocking with not that swim store stuff"
    Regards
    Aug 2011
    Nassau Bay, TX
    199
    Re: Cloudy pool
    Are you going to use the BBB method?
    Nov 2010
    Calera, Al
    271
    Re: Cloudy pool
    Quote Originally Posted by sunny8088
    Regards
    You really need to read pool school... Shocking is a process not a product you dump in the pool.... To shock you maintain a high fc/cya ratio as stated here: pool-school/shocking_your_pool
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Aug 2011
    Nassau Bay, TX
    199
    Re: Cloudy pool
    Sunny, as stated several times already, you need to become familiar with Pool School. Especially the section Rob just pointed out regarding Shocking.
    And yes, as Rob eluded to....Shock is a verb, not a noun. Do not buy "Shock". That is the reason I asked if you were going to use the BBB method. The only reason I can see myself going to a pool store ever again is if my test kit was somehow unusable and I needed a quick test (which I still wouldn't fully trust for an extended period of time).
    Going by your pool company's numbers, it looks like you'd have to add 684 oz of 6% Bleach to get to shock level. That is assuming you haven't lost any in the last two days, which you probably have. You might want to get a newer test than 2 days ago.
    Can't stress the importance of a good test kit. I hope yours is delivered soon.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: Cloudy pool
    Most of us use Bleach from the grocery store or walmart to shock and maintain chlorine with. We use the cheapest stuff we can find and still have the proper amount based on percent. Most, not all, grocery store bleach is 6%. Sometimes you will run across 5, 10 or 12%, just make sure if you use that to plug that percent into the pool calculator and it'll tell you how much to use to get to your target.
    I agree you should get at least some chlorine into the pool or you'll have a full blown swamp.
    Dan D
    Sep 2011
    Houston, TX
    38
    Re: Cloudy pool
    And although 684 oz of bleach sounds like a shocking amount, pun intended, it is not too much to get your pool up to the required chlorine level for the shock process. And it is cheaper than the pool store "shock" material which will add undesirable additional calcium. Just learning myself, but was put off at first by the idea of buying gallons of bleach. Read up on it and it just makes sense.
    26600 Gallon | In Ground Plaster
    Sand Filter Hayward S310S 500 Lbs Sand 4.9 sqft | Pump Hayward RS1500 (1.5HP motor)
    Jul 2010
    Longwood, FL
    151
    Re: Cloudy pool
    Thank you all for all you comments.
    They are very helpful. I will go & shop for test kit & bleach as suggested.
    Will keep you posted.
    Regards
    Jul 2010
    Longwood, FL
    151
    Re: Cloudy pool
    Ordered TF-100 from http://tftestkits.net. Going to Walmart to get my 6% bleach .
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    Re: Cloudy pool
    Your pool didn't come with a vacuum? Do you see anything on the pool floor like dirt or algae? You really need to shop around for a manual vacuum, you can buy an expensive one that will do it for you, but I prefer to do it myself.
    14,700 gal. 14 x 28 rectangle with 2R IG by Hydra Pools, 1 hp Hayward Maxflow ll, Hayward 24" Sand Filter, Aquarite Electronic SWG, one Aqua Genie Complete Skimmer, two main drains, four returns, 2 spa jets in steps, 30ml Tidewater liner. Taylor K-2006 Test Kit
    Aug 2011
    Nassau Bay, TX
    199
    Re: Cloudy pool
    Smart move on the kit. Get a lot of bleach! I use the "Great Value" brand and it works great. Just double check and make sure it's 6%. It's about $2.80 I think here for the 182oz bottles.
  20. Back To Top    #20
    Jul 2010
    Longwood, FL
    151
    Re: Cloudy pool
    As you know
    1. Ordered the kit yesterday (shipped in 1 hour)
    2. Went to Aldi got lot of 6% bleach
    3. Getting Baracuda G3 today
    Pool is blue but still cloudy.
    Will get in action when kit arrive. Will go to pool store to get the numbers.
    Thanks
