Thread: Water temperature
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Water temperature
    I use the drops method of testing (not test strips) to check my hot tub water. I keep the water at 100*. Should I test at that temperature or let it cool to room temp? Does it make any differance?
    Thanks
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    You should do the tests with water straight from the tub. If you take a water sample and let it sit the chlorine/bromine levels can drop noticeably.
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Thanks, I'm doing it correctly.
    Mesa, AZ
    16
    One test that you should wait for the water to cool down for is CYA. It is essentially a solubility test and the solubility is higher at 102
    Chris W
    My Pool: 14K gal IG, Pebblesheen, Pentair 420 Cart Filter, Autopilot Digital SWCG, Paramount PV3 In-floor cleaning. UltraPure Ozone
    My Spa: 2007 Down East Windsor SE, Spa-Pilot SWCG :)
    My Kit: PS-234 w/salt test, Refills from Taylor and TFkits
