Results 1 to 9 of 9
Thread: Vacuum pool for 5 minutes, already coming out dirty
    Oct 2010
    michigan
    284
    Vacuum pool for 5 minutes, already coming out dirty out of jets/return
    15,000 gallon inground pool with spa, 350lb sand filter, 1.5 hp pump, gauge PSI 20
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    30,403
    Re: Vacuum pool for 5 minutes, already coming out dirty
    clean your filter.
    Oct 2010
    michigan
    284
    Filter is 2 years old, and i backwash for about 5 minutes till crystal clear coming out
    30,403
    Do you rinse correctly after backwash? Is your pool exceptionally dirty? If you have a 350 pound clean sand filter, you must be sucking up a lot of dirt awfully fast for it to spew the dirt back. Give us a little more information and perhaps we can get you a little better advice.
    Oct 2010
    michigan
    284
    Pool water is clear, as all the dirt is settled on the bottom, there isn't much dirt, just enough to require a vacuuming, 15 x 40 foot pool. sports pool
    When i backwash, i backwash till the water is clear, usually atleast 5 minutes. then rinse for 30 seconds
    I use a white bucket to make sure its clear like the pool.
    Vacuum
    Why i don't understand after 5 minutes of vacuuming it spews the dirt out of the jets.
    is the dirt so thin it gets thru the sand? or something wrong with the filter internally?
    30,403
    For the first five minutes that vacuum works just fine and collects dirt, right?
    Oct 2010
    michigan
    284
    yes.
    30,403
    Well, something is changing after five minutes. That would seem to indicate your filter is being plugged up by debris. If it was damaged, it would spew back on start-up.
    Have you opened the filter up to look at the sand?
    Oct 2010
    michigan
    284
    gonna open it up today and see if there is any channeling
