Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
Thread: Central PA Pool Build
  1. Back To Top    #21
    Re: Central PA Pool Build
    Well of course more challenges. The PB's put in about a 15 hour day. Did full bottom and then around 7pm (EST) pulled liner from box and started to install. This 28mil product was attempted to be suctioned by (2) vacs and just would not fully pull into walls. Some water was added to assist, but the lack of sun/heat did not allow the liner to lend itself to working wrinkles out and staying put. At 9:30PM last night they sent home the water trucks and left the liner in with vacums and about 3' of water in deep end. I guess we wait for some warmup and NO RAIN!! Supposed to rain in PA for next few days, with nothing good during week until Monday.
    Should I be concerned with it sitting like this for next 3-5 days?
  2. Back To Top    #22
    Well, they must have been concerned leaving in that state. They showed up and are working liner and filling.
  3. Back To Top    #23
    Liner is in and fits like a glove:
  4. Back To Top    #24
    That is one amazing looking vinyl liner pool. The coping looks great!
    Under construction DIY 20x40 vinyl liner steel wall pool, Pentair 2hp wisperflo, Pentair tr100 sand filter, Pentair Minimax 400k heater, diving board, 8 foot sit n step, xtream waterslide, 1700 concrete deck, one amazing wife, 4 children and two German shepherds.
  5. Back To Top    #25
    Been a busy couple days. Concrete competed Friday. Electrical, gas and plumbing all done. Automation setup and SWG working. Tested heater for the day and got about a 5 degree lift in 8 hours. Just testing as it is 58F outside!!! Also, my brother and I build the fire pit for natural gas fire ring (HPC 24" high output).
    1500 sq feet of concrete total around pool and patio extensions. Lots of landscaping cleanup and not much time!!
  6. Back To Top    #26
    Aug 2007
    near the swamp
    806
    fix your images please
  7. Back To Top    #27
    Thanks DBFan. All fixed.
  8. Back To Top    #28
    Looking for some input. Thinking of using 1-3 river bottom stone to fill all area to right of concrete/pool in this picture, then using dark brown mulch to go around Thunderhead pines (away from pool) and 6' white privacy fence.
    Any thoughts or suggestions?
  9. Back To Top    #29
    Any comments on river rock? 1-3 and/or 3-6 sized. Any experience or pics.
  10. Back To Top    #30
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    3-6" will be too big to safely walk on (twisted ankles galore). 1-3 would work. I bet both will be quite expensive.
  11. Back To Top    #31
    Cost is $20 a ton for either. Quary is right down the road.
  12. Back To Top    #32
    Busy day today. Got some more stones in place, planted two really nice ThunderHead pines, cut the 20x40 rectangular solar cover to shape and installed a Arizona sunburst metal sun on fence. Whew.... wish i could grab a beer and go for a swim, but at 56F I will just settle for a beer!
  13. Back To Top    #33
    Feb 2012
    Lancaster, PA
    112
    That looks nice! I am thinking of using the same type of stones along my rear fence area so that I won't have to worry about mowing between my future patio and the fence. I like the sun, too. I just saw a similar one at Costco and I regret not buying it. I need to be done with the pool build before I start decorating the fence that I can't even get to now!
    16 x 32 vinyl In-ground Lagoon; Shallow pool 3' to 5'; Buddy Seat; IntelliBrite 5g LED; Pool Pilor Digital SWG, Pentair Clean & Clear Plus 320; Pentair Intelliflo VS + SVRS; Pentair Sand Shark. My Construction Thread - Spring 2012
  14. Back To Top    #34
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Do you have any close up pictures of your coping? How smooth/rough is the inside edge of it? Thanks and Looks Great!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
  15. Back To Top    #35
    The edge is not smooth, but not really rough. It's decent, but I think if worked a bit more with foam patterned block as it set, it would have been smoother. All but one minor spot is solid and that was due to some type of debris being between concrete and form. I would do it again.
    If you click on the properties of my pics, you can go to the site and there should be two pics of the edge prior to pool being completed. I am at work at Photobucket is blocked.
  16. Back To Top    #36
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Quote Originally Posted by thadius65
    Okay i found the one real close up of the inside of the coping, looks pretty smooth. Thanks!
    18'x43' Sport Pool
  17. Back To Top    #37
    Hey its Rob, Rome is putting our pool in. First Monday in June. I really like to see a picture of your pool finished if you have the chance. :P
    Simply, we find, hire and train the most talented individuals possible and we work hard to keep them.
    Autoform
  18. Back To Top    #38
    Rob - With the exception of the ladder/rail, the above is from 5 weeks ago. Been swimming 3 out of last 5 weekends with 83F water!
  19. Back To Top    #39
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Nice job!!
    The cement work on page 1 looked perfect!
