Results 1 to 9 of 9
Thread: Pool light faceplate
    Mar 2009
    Indianapolis, IN
    70
    Our pool is 6 years old and the pool light faceplate is so corroded and gross. What causes this and can just the plate be replaced?
    Thanks!
    18x36 ft
    19,000 gal IG vinyl
    Sand filter Tagelus 24"
    1HP Whisper Flo Pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pool light faceplate
    That's often a symptom of an electrical problem. What light do you have?
    Mar 2009
    Indianapolis, IN
    70
    Good question! I just looked at our papers from the company that installed the pool and all it says is "300 watt standard light". My husband was planning trying to remove it later tonight to take a closer look. What kind of electrical problem?
    18x36 ft
    19,000 gal IG vinyl
    SW Indiana
    9,199
    Quote Originally Posted by jmlodin
    Usually improper grounding or a missing or loose neutral.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    A picture would help. It could be something else.
    Mar 2009
    Indianapolis, IN
    70
    The information about the brand is American Products Pool Light
    AMP78434100 Light
    AMP78232400 Niche
    AJGMT300 Transformer
    We just removed the light and there was SO much black gunk that just came floating into the pool. It is also all over the back of the light and the niche looks totally lined with gunk. Any ideas??
    18x36 ft
    19,000 gal IG vinyl
    What does the power cord look like? Sometimes the cord will disintegrate and get black crud all over. Another possibility is black algae.
    South Central NJ
    3,192
    That looks like either a low pH condition over an extended period or, as was mentioned earlier, an electrical issue such as a bad ground or neutral. Note the extent of the pitted metal parts. That leads me to consider a low pH condition as the more likely culprit.
    Scott
    Owner of - PoolGuyNJ LLC
    Mar 2009
    Indianapolis, IN
    70
    It is definitely not low PH unless something is wrong with my Taylor test kit because I check that nearly every day and it is usually 7.6. I guess I need to get the electrical checked out.
    18x36 ft
    19,000 gal IG vinyl
