Thread: Test Vial
    Test Vial
    I broke my Chlorine Only test vial. Will someone please tell me if it's ok to use the 25ml vial for cl test until i get a new cl vial. TF100 test kit. THANKS
    20X40 IG,33,000 GAL,VINYL LINER,1 HP PUMP,HAYWARD SAND FILTER,CAMDEN,S.C.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,078
    Re: Test Vial
    From what I read the only reason there's two are because the chlorine only one tends to get a black ring on it. Other than that....yep you're fine.
    30,403
    Re: Test Vial
    Leebo has it absolutely correct. They are identical but the FAS/DPD test tends to leave that residual black ring which may or may not cause just a little interference on the other tests.
    Re: Test Vial
    Double or triple rinsing before and after testing can help reduce vial staining and cross contamination of other tests.
    Support the site
