Thread: liner floating
    liner floating
    with all the rain here in pa my liner has floated, any suggestions on how to deal with it? Grin and bear it and just wait till the water pressure is less and the liner sucks back in? wrinkle city?
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    heat siphon heat pump
    Re: liner floating
    Welcome to TFP!
    It all depends how far it has moved. If the movement has been small and mostly away from the walls, rather than shifting horizontally along the walls/floor, you can just raise the water level in the pool and things will go back to normal. For somewhat larger amounts of movement you can slowly raise the water level while brushing/tugging/pushing the liner back into position. If the liner has shifted too much you need to drain the pool and reset the liner (if it isn't too old) or replace it (if it is older).
    Re: liner floating
    Welcome to TFP!
    hmm water is almost to the top already... we had over a foot of rain in 2-3 days... but thanks.. the pool is 5 years old dont know how much its been stretched out by this
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    Re: liner floating
    If the builder put in an underdrain (basically, a well point going under the pool to keep the water under control while the pool was being built), you can put a pump on it to lower the ground water a little bit.
    Support the site
    Sep 2008
    Philadelphia
    43
    Re: liner floating
    25,000 gallon
    16' x32' Rectangle IG, Vinyl liner
    DE filter
    Re: liner floating
    Quote Originally Posted by JamesW
    the pool builder was a moron ( me ) and set the whole thing about a foot to low, normally not a problem if the water level is up in the pool. I thought about drilling a hole near the pool and putting in a sump but just how far out is the ground water... could be pumping to relieve the pressure for weeks?
    if i have to change the liner i may do what you suggested
    thanks
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
