Results 1 to 10 of 10
Thread: circulation help
    Jul 2011
    Canton, MI
    47
    circulation help
    I've been having circulation problems all year on the bottom of my pool. I have a 28ft 17,500 gallon round above ground pool with only one return jet. I've tried aiming the jet in all directions possible (except up) to improve circulation on the bottom of the pool, but nothing has worked. Anytime the FC drops to the target level (well above min FC) the bottom turns green, except near the return jet. The previous owner dug the middle of the pool out so it's around 4.5ft deep in the middle, 3.5ft deep around the edge of the pool. I've read the reviews on "the circulator," and it seems like a shady product that doesn't work well. Any ideas on how to improve circulation for next summer? Are there any underwater fountains that I could hook up to the return jet that would sit on the bottom of the pool? Thanks for you help!
    17,500 gallons, Vinyl, Above ground, Hayward Sand filter, Hayward 1.5hp pump
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: circulation help
    How about plumb in a second jet and aim it at the center of the pool. It sounds like your not getting good circulation to begin with. How is your return aimed? What's the pump run time? Maybe it's too short. Or keep your FC level higher. Are you using pucks or liquid bleach? If your using pucks do you know your CYA level and have you taken that into account with the FC level?
    Jul 2011
    Canton, MI
    47
    Using liquid chlorine on the BBB method. Pump runs 12 hours/day, and jet is aimed diagonally down and right. I'd love to add a second jet, but I have no clue how. Is that expensive, or difficult to do myself? Also not sure how I would hook another return line to the hayward sand filter.
    Jul 2010
    Philly
    332
    I would rule out the other reasons for algae before cutting another hole in your pool. Not saying you don't have a circulation problem but with a relatively clean filter and a properly working 1.5 HP pump, your circulation should be more than sufficient.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
    Jul 2011
    Canton, MI
    47
    I've already ruled all other ways to get algae that I can think of. Did a complete mustard algae treatment twice, cleaned the solar cover pool toys, behind lights, washed suits, etc.
    30,403
    I am not familiar with the return jet fittings for AG pools, but if the eyeball screws in, you can screw in some type of PVC adapter and either direct the water stream down or actually make something out of pvc pipe that travels to the bottom of the pool and then turns 90 degrees to distribute the water parallel to the bottom of the pool.
    That said, how are you testing your FC level? We have VERY few (if any) reports of inadequate circulation in a pool like you describe and I suspect your FC is (has been) chronically low.
    Jul 2011
    Canton, MI
    47
    testing FC using the TF100 FAS/DPD tester.
    30,403
    What is your current CYA level and how does your water look right now?
    PS - I think your caution about the "circulator" is probably valid.
    Sep 2008
    The Woodlands, Texas, USA
    243
    I agree with the others. I don't think the algae is a circulation problem.
    I have personally used the circulator and it works, but honestly it is a solution looking for a problem to solve.
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
    Jul 2011
    Canton, MI
    47
    CYA is somewhere between 50 and 60. I'm in the shock process now so the water is blue, but slightly cloudy (dead algae). Once the shock process is done I think I'll shock to mustard algae levels for CYA 60-70 (just incase) for 24hrs, then close the pool after the FC level falls to normal shock level (short pool season in Michigan)
