Results 1 to 10 of 10
Thread: zodiac saltnator problem
    Hi new to this all is good water is. Clear just cannot use controls on my zodiac saltnator all green lights are on can not. Lower to say 3 lights or 2 or turn it off sing. The. Onof botton. Thanks
    Re: zodiac saltnator problem
    Sorry my fingers are too large for my iphone sorry for the spelling mistakes what I meant to say is all green lights are on. I have no control to ajust them or 2 shut the system down on the unit I have to shut it down using the main switch which is connected with pump ghanks
    Apr 2009
    Burlington, ON, Canada
    344
    What model is the Zodiac? I'm pretty sure they don't have a model called the 'saltnator'.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Lm2-10 clearwater
    Apr 2009
    344
    Is it in 'superchlorinate' mode? This will run the system at full output (all lights will be lit up) for 24hrs (that's pump run time, not 24 hours in a row) then the lights will go back to whatever level it was set to before superchlorinate. To turn off superchlorinate, simply push the 'superchlorinate' button.
    That's to easy I have done all that my nabours boyfriend said the same thing. Thanks Cecilia I even tryed disconnecting the red blk blue wires one at a time and nothing the reset does not work as well. I have it down for20 or30 sec no reset thank you Cecilia
    Well anyone have any idea?
    Thanks
    22,551
    Sounds like the control board. How old is the unit?
    The controlled board is 5 years old thanks
    Jul 2014
    Oakville
    2
    Quote Originally Posted by juve10 View Post
    Hi Juve, did you solved your problem? It looks like I'm facing the same issue and would like to know.
