Thread: Stupid question of the day
    I'm trying to clean my jandy aquapure cells by myself for the first time. I could easily unscrew the collars on the near side (bottom) of the cells, but on the far side (top), the collars won't budge. In fact, the force is starting to twist the plumbing lines. Should I be using "lefty to loosy" in the opposite way for the top collars? In other words, should I be standing on the opposite side of the equipment to get the "lefty to loosy" for the top collars? Am I making any sense at all? LOL
    39,000 gal 48 x 22 gunite/pebble, SWG
    Pentair Intelliflo
    Jandy Aqualink RS; Jandy 60 DE Filter
    Polaris 280 Black "Manta Baby"
    3 Jandy WaterColors LEDs
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Stupid question of the day
    Yes try turning it the opposite direction
    Luv& Luk
    -Ted
    Oct 2010
    Houston, TX
    152
    Quote Originally Posted by stricttime
    Not a stupid question at all. I think we've all made this mistake. One time I couldn't get a garden hose off of a water valve and I tried lots of brute force with channel lock pliers, WD-40, hammers, etc. Totally screwed up the garden hose attachment. Then I looked on the web and saw many people had the same problem... One answer someone submitted was "try turning it the other way... seriously."
    One easy quarter turn the other way and I was then able to unscrew it off by hand.
    Lefty-loosy is looking from the direction of whatever you are screwing on. (and not from the valve down to the garden hose in my case...) The only exception I can think of is with things like toilet handles so the action of the handle doesn't unscrew off the handle.
    15k gunite pool. Intelliflo VF. Autopilot SWG.
    2k separate spa with waterfall (ie: pain in the rear maintaining a separate body of water). 2HP Hayward Tristar pump.
