Results 1 to 14 of 14
Thread: TF-100 Test Kit Problem
    Apr 2010
    Laguna Niguel, California
    21
    When conducting the Calcium Hardness (CH) test using the TF-100 Test Kit, I get pinkish precipitate in the solution when I add the R-011L reagent. When I then add the R-0012 reagent, I get no color change, regardless of how much I add. I don't add copper algecide to my pool, but I did the R-0012 add prior to the R-011L reagent anyway with no change in results.
    What is the problem?
    20K IG SW White Plaster Pool & Jacuzzi -2 HP Hayward EcoStar Pump - 70ft2 150GPM Hayward Pro-Grid D.E. Filter DE6020, Hayward AquaRite SWG Auto-Chlorinator with 25,000 gal Turbo Cell, TF100 Test Kit
    Laguna Niguel, CA
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Re: TF-100 Test Kit Problem
    You didn't forget the R-0010 did you?
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Quote Originally Posted by Mark92677
    Mind if I ask how much exactly is "regardless of how much I add"?
    CA water is often high in calcium. Is it possible you're giving up too early? CH in the upper 400-600's isn't uncommon. Especially with pools chlorinated with cal-hypo at any previous point.
    What is your pool's history? Can you post a full set of results?
    If you're getting an actual pink result at first, you have some calcium, you just need to find the cap. I haven't ever seen pink. I get a dull brownish yellow at first when I test both the pool and the tap water. Pool is about 20ppm, tap is 2ppm. Neither turn anything close to pink when I begin the test. The test calls for a red to blue change (brownish yellow is a degree of red => blue, as I see it). I see a blue tint and then no further change with additional drops. The drop that turns it tinted blue is the value I record.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Mar 2007
    San Rafael, CA USA
    12,082
    As described here, metal ions can interfere with the Calcium Hardness (CH) test creating the pink floaties you are seeing and making the endpoint fade or be less distinguishable. You can add some (say, 5) drops of R-0012 titrant first to the sample before you add the R-0010 calcium buffer or R-0011L indicator dye. Though you might still get some floaties, the endpoint should be more distinct.
    If you think your CH might be high, then use a 10 ml sample size where each drop is 25 ppm (see this page for instructions on this where you use 10 drops of R-0010 and 3 drops of R-0011L).
    30,426
    Adding to what Richard posted, your thread from April of last year indicates a HIGH concentration of metals in the water......not black algae. If that was never resolved, it would certainly explain the "floaties" in the CH test.
    Apr 2010
    21
    Yes this is true, I did have high copper content in the water. I completely drained the pool, flushed the plumbing with fresh water, replaced the filters and all of this after I had given the pool a wash with Ascorbic Acid to remove the copper stains.
    So the pool has all new fresh water.
    So far, nothing that anyone has said accounts for the precipitate (soft clumps) that are created when I add the R-0011L reagent, which of course follows the R-0010 reagent which has thoroughly been mixed in solution. The question is, what chemical reaction could cause this formation of precipitate. The test instructions and the test kit web site don't even address this possible reaction.
    Laguna Niguel, CA
    Apr 2010
    21
    Quote Originally Posted by chem geek
    I'm not so sure that the CH is high as it appears that some other chemical reaction is occuring that is interfering with the test, or there is something wrong with the reagents.
    I'll try adding 5 drops of R-0012 prior to and see what happens.
    Laguna Niguel, CA
    Apr 2010
    21
    Quote Originally Posted by Richard320
    Nope!
    Laguna Niguel, CA
    Apr 2011
    Maryland
    18
    Mine does the same thing, never turns red, just pink and has never turned blue, I have put a half a bottle of 0012 and it went clear. What I have been doing is going to the pool store, they use Taylor drops and I watch them do the test counting drops and it turns red and then blue and I dont know why, I use there number for CH and mine for everything else
    18000 gal Gunite free form
    Jandy 1 HP pump
    Jandy DEV 48 filter
    Raypak 400 heater
    Goldline Proligic SWCG
    Solaxx chemical feeder
    Dolphin Deluxe 4
    30,426
    Quote Originally Posted by chucklh
    I assume you are using the TF-100 for testing CH.
    It is, in fact, the Taylor test you are performing. It is their chemistry. I can't explain why the pool store is getting results and you are not but the tests are identical in every way.
    22,551
    On the CH test especially, swirling makes a huge difference in how the color progresses. I suggest you get a speedstir if you don't already have one and see if that helps.
    Aug 2010
    Boston, MA
    176
    When I had a similar effect, I was told by Richard and Jason that high FC could be the reason. What's your FC?
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
    Make a sample of 50 % pool water and 50 % distilled water. Mix well. Follow these steps to test:
    1) Rinse and fill large comparator tube to 25 mL mark with water to be tested.
    2) Add 10 drops R-0012. Swirl to mix.
    3) Add 20 drops R-0010. Swirl to mix.
    4) Add 5 drops R-0011L. Swirl to mix. If calcium hardness is present, sample will turn red.
    5) Add R-0012 dropwise. After each drop, count and swirl to mix until color changes from red to blue.
    6) Add the original 10 drops of R-0012 to the number of drops needed in step 5, and multiply the total number of drops by 20. Record as parts per million (ppm) calcium hardness as calcium carbonate.
    Support the site
    Apr 2011
    Maryland
    18
    I do have the speedstir and love it.
    I hold the FC at 6 with a CYA of 60
    Jandy 1 HP pump
    Jandy DEV 48 filter
    Raypak 400 heater
    Dolphin Deluxe 4
