Thread: Algae growing in AG pool ladder
    rwrogers11's Avatar
    Apr 2011
    Katy, Tx
    66
    I pulled my ladder out today to scrub the pool real good and noticed algae growing all in the back side of the ladder. Its a plastic type of ladder, and has a bunch of areas on the backside for junk to grow.
    I just recently had an algae bloom in the pool and used yellow out to get rid of it, the pool is sparkling clear, but then I saw the backside of the ladder. I would have thought that using yellow out and shocking the pool would have gotten rid of the algae, but I guess not.
    Just curious, how often should I be cleaning the ladder, whats the best way to clean it, etc.?
    Richard
    Pool - 18' Doughboy Above Ground Vinyl, 7600 Gallons, 1HP Hayward Power-Flo Matrix pump, Hayward Star Clear Cartridge Filter C500 50 GPM flow rate, Hasa Chlorine Injector, Pool Rover Vacuum, Taylor K-2005 Testkit - Hot Tub - Artesian Pelican Bay, 550 Gallons, Ozone, Nature 2 Mineral Sanatizer, Bromine floater.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,273
    Re: Algae growing in AG pool ladder
    It is best to clean the ladder when opening the pool and keeping the FC in range so algae blooms don't start. After an algae bloom you should check behind the ladder and any other nooks and crannies with poor circulation and give them a good scrubbing. You shouldn't be able to swim behind the ladder and they are too much of a pain to pull and wash on a regular basis. When adding bleach to the pool pour a little around the ladder to make sure you get some chlorine in the area.
    Love TFP? Become a
    TFP Supporter!
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    We have a very similar setup and every year that I remove the ladder there is a lot of green algae growing in the back. This year is my first with TFP and it's philosophy of pool care so I kept a very close eye on my water levels. Never had a CC problem, never had an algae outbreak, never flunked an OCLT which I run weekly and never lost more CL per day than expected. I had a great pool year and for the eleventh year straight, I pulled my ladder out to close the pool and it had algae behind it.
    My conclusion? With the best water maintenance imaginable, if there is an area that gets little circulation, algae will form but it does not mean your pool is in trouble.
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
