Thread: Building material for outdoor kitchen
    We will be building an L-shaped outdoor kitchen on a covered patio. In this design, we will have a stainless steel sink, green egg and luxor infrared grill. We have chosen to use coronado stone for the finish on the kitchen with a granite countertop. We are needing stainless steel doors and also need to seek advice as to what materials to use to build the structure. Recommendations have ranged all the way from wood to concrete blocks. Would appreciate hearing from others as to where they used to construct their kitchen, where they got their stainless steel doors and just overall advice on this project. Thanks
    pool products ~ above ground pools
    "The man who is swimming against the stream knows the strength of it." ~ Woodrow T. Wilson
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Building material for outdoor kitchen
    I would use steel studs and cement board for the sides. That's generally the way it's done, though concrete block could work. I would stay away from wood, since it burns ya know
    we used steel and cement board...got the SS doors from Amazon.
    14,000 gallon IG plaster pool, Cartridge Filter
    Jul 2011
    Tempe, AZ
    37
    Agree. Use steel studs. Very easy to work with once you get going.
    In process of beginning Pool project
    18x35 pool, appox 22K gallons
    will add more as the project firms up.
