Thread: Latest time in year to dig concrete pool in Oklahoma
    After finally deciding to go with a concrete pool with pebble tec, how much time should we allow before cold weather sets in? In other words, should we postpone the dig until next spring? Freezing weather can occur in late Oct or early Nov in Oklahoma. Seeking advice from pool experts on this forum. Thanks
    pool products ~ above ground pools
    "The man who is swimming against the stream knows the strength of it." ~ Woodrow T. Wilson
    Re: Latest time in year to dig concrete pool in Oklahoma
    The plaster needs to be protected from freezing during the first several days. While it is possible to enclose and heat the pool area while pouring concrete and/or applying plaster/pebbles, it is much simpler and less expensive to do all the concrete and plaster/pebble work before there is any chance of a hard freeze.
    Jul 2011
    Broken Arrow, OK (Tulsa)
    294
    Our dig should start in the next 10-14 days. We aren't concerned about a freeze at this time, as we usually don't get one until November or so. We aren't going with PebbleTec...we chose Quartzscapes instead.
    16 x 31, Approx. 12,000 Gal Freeform IG pool; Flagstone coping; Quartzscapes Super Blue plaster finish; Tanning ledge w/2 bubblers; 1 HP Pentair Whisperflo pump, Pentair sand filter; (2) Pentair Intellibrite LEDs w/controller; Easytouch8 w/IC-40 SWG; Salt finish concrete decking.
