Thread: Sandstone Pool 24' Above Ground
    I found a great deal on this pool but it does not include pump, filter, liner. I already have all of that and my current pool is rusted so bad by the suction and return from the previous home owners. Is this pool a decent pool to last us a few years. We live in South Louisiana. Here are some specs on it. 24'x52"
    Sandstone above ground pools feature a unique and solid design that provides maximized strength and durability so you can enjoy your pool year after year. The neutral shaded walls have been constructed with premium hot-dipped galvanized copper bearing steel ensuring corrosion resistance and weatherization protection.
    Rugged coated 6 in. Painted Top Rails and 5in. Verticals
    Poly-Lam™ coated, baked-enamel, 52 in. high pool walls
    Oval pools feature conventional strap buttress supports
    24' Round Above ground 13,500 gallons
    1.5 HP pump.
    Vinyl Liner
    150sqft Cartridge Filter
    Bottom Drain
    22,553
    Re: Sandstone Pool 24' Above Ground
    If it's a good enough deal and it's not rusted or bent I'd go for it.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    I went and picked it up today, brandnew in the box just like it was delievered. It sat on a ladys porch for a year, no rust or anything. Picked it up for $450, already have a 1hp pump, will get a new filter and liner. So I will be around 1k. Not to bad
    1.5 HP pump.
    Vinyl Liner
    Bottom Drain
