Thread: Raising CYA using Dichlor
    May 2011
    Los Angeles, CA
    228
    Hello all!
    Just as you said a few months ago, my CYA has dropped from 65 to 45 due to splash out.
    I would like to raise it to 50-55 using dichlor. Any general ideas how long i should switch to dichlor to get the CYA to 55?
    I dont want to keep testing for CYA to save chemicals... I know i know I am being cheap here
    Thanks!
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    Re: Raising CYA using Dichlor
    Use the Pool Calculator to figure out how many oz of dichlor it will take to get your CYA from where it is to where you want it. (I get 60 oz)
    Then figure out how much dichor you need daily, as you test FC daily. (I get 10 oz volume for 2 FC added)
    Keep track of the tally and at some point you will have used the total. (I get 6 days at 10 oz volume per day)
    Go back to bleach for a week or two before testing the CYA, so that you are sure that it will show up on test. (But test is +/- 15 ppm accuracy so don't bother testing.)
    May 2011
    Los Angeles, CA
    228
    Thanks!
    I keep forgetting to look at the lower part of the pool calculator!
    Aug 2011
    Houston Texas
    17
    Quote Originally Posted by Suley View Post
    Thanks!
    Thank you! I was looking for the same info and overlooking the drop down at the very bottom. Thanks for mentioning where it is.
    Circa 2000 - IG 20k Gallon Plaster/Gunite Pool - Painted (though much of the paint has worn back down to the plaster)
    FNS Plus DE Filter (60 sq ft?) - Formerly paired with 3/4 hp Pentair Challenger pump
