Leaking pool
Jeff74
Mar 10, 2010
150
Huntington, WV
Our AGP is in its 2nd season and we are getting ready to close. I notice there is a leak coming from the bottom ring. I was wondering what the policies and procedures for getting warranty help on getting it replaced are? What will the liner company require from me? Will they cover a busted seam or hole? Obviously I have yet to call the liner company as I am still trying to find my receipt and warranty card. Will they need the warranty card or just a receipt showing item and date of purchase? Thanks.
Seam yes. Hole no. If hole swim down and pach now while water is still warm enough. My liner seam split after 1 week installed and the online company i purchased pool from had me take pictures and email them the pics. They sent it right out. I had to pay for a new install and water though.
The bottom ring of the pool, I can see water coming out from under it. So, I have narrowed it down to what I think is the general area of the hole. The water is too cold to get in, but I am losing water fast. I may wait to see if the leak stops and then check the liner around the water level at that point, otherwise, I may be getting some scuba gear on and taking a dive with some food coloring. I really just wanted to know if they required anything other than the invoice as I do have access to that.
I was able to find the hole when I dived into sub 70 temperatures the other day. I used some red food coloring to find it and now it looks like there was a shark attack. The hole was about the size of a pea, not sure how it got there, but according to my experienced pool installer, the liner manufacturers usually will not help you if it is a hole and not a seam issue, they will simply call it user abuse and be done with it. Anyways, I patched it under water, retested it right away and it seemed to have stopped a bit. I refilled the pool to normal operating level, drew a line on my skimmer box with a sharpie of the water line. I have noticed in about 3 days that the water has dropped about 1/2". Do you think this is normal evaporation? It has been warmer here in the last couple of days (around 80), but at night it drops to around 50's. I will probably take advantage of this warmer weather and jump back in to retest with food coloring in a couple days, but for the most part I assume the water loss is due to evaporation. Thanks.
I ran the bucket test and just over about 18 hours it shows about the same amount of water leaving the pool as well as the bucket (about 1/2"), so that means it is evaporation. However, we have had temps in the 60s/70s and 50s at night and hardly any sun. My pool does not have any shade until late evening, but with those temps would the water still evaporate that quickly?
