Thread: LQ appears to be using too much chlorine
    Jan 2011
    Riverside, CA
    352
    I'm not sure exactly how large my pools is, probably somewhere between 25,000 and 29,000 gallons.
    Last month or two is has been warm down here in SoCal. My pool has LOTS of sun exposure (from about 9 am to just about sunset 6-7 pm). It went through about 3 gallons of 12% in about 2 weeks. It may have been a little more chlorine, but it's hard to get an exact level.
    I tried to calculate the monthly cost for tablets vs liquid chlorine. I think 1 gallon a week is about the same as the tablets (maybe a little more for the liquid).
    Is the pool too big and/or in too much sun for the LQ? My CYA level was about 55 when I checked 10 days ago.
    I can put the floats back into the pool for a month, I still have a bunch of tablets.
    Am I missing something?
    40x20 Free Form IG Pool (aprox 29,000 Gal, 140 Perimeter, depth 3'6"-7', Baja Shelf, 8x8 Free Form Spa) - Gunite Shell, Pebble Plaster Finish, Poured Concrete Coping - 3 Deep Heat Returns - Jandy LXi400 Gas Heater (400,000 Btu) - Jandy Variable Speed Pump JEP 2.0 - Jandy CL 600 Filter - HASA Liquidator - Jandy PDA 6 w/ Remote - 4x Jandy WaterColors Pool LEDs - 48" Gas Fire Pit - 6x Gas Tiki Torches - 12'x15' U-shaped BBQ Island (Firemagic Equipment)
    http://www.troublefreepool.com/new-p...ca-t28413.html
    22,553
    Re: LQ appears to be using too much chlorine
    If you're losing about 2 ppm per day, which is pretty normal your daily use will be between 3 qts and a gallon of 6% per day. Or about half that much 12%. 3 gals in 2 weeks is about 1 qt per day which is darn good.
