Thread: Closing Pool
    Closing Pool
    I am closing my pool in 11 days.. Do I still need to run the filter as usual and keep adding chlorine,etc? Or does it even matter now since I am closing the pool..
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    22,539
    Re: Closing Pool
    Keep it running and keep the FC up. If you close it correctly, your job at opening next year will be much less of a hassle.
    Apr 2011
    Lynchburg VA
    393
    Re: Closing Pool
    I will be closing mine as soon as the pool temp drops below 60 degrees. Until then I am planning on running my pump 12 hours a day which is normal for me. A day before closing I am going to be bringing my FC up to shock level and adding polyquat to the pool. The day of closing I will again make sure the FC is at shock level and I will begin lowering my water level and blowing out the lines.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Re: Closing Pool
    I think my water temp is probably around 75, if the solar cover was off it would likely drop a good 10 degrees in a few days I'm assuming. So I'm thinking now is as good of time as any, plus the steps are still in and I don't want to feel like I'm a kid swimming in Oregon when I have to get in to remove the weights.
    This could probably be its own thread, but if I used half a sample for the FC test could I count the 1 drop as 1ppm instead of 0.5ppm? I've seen dilution with distilled water mentioned but not using half the sample size. (Taylor FAS-DPD)
    I was hoping for one last good swim (weekend preferably) but the forecast changed and I've decided it's officially over
    even if I ran the heater non stop, it's going to rain and be in the low 70s.
    Can someone tell me, does it ever get easier to end the season?
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
