Results 1 to 9 of 9
Thread: Pump impeller size?
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Pump impeller size?
    Back-story: Got a pump with a pool that I acquired http://www.troublefreepool.com/pool-removal-t37997.html. It's a Hayward PowerFlo with an Emerson 1 1/2 motor. Pump was very stiff to turn and after some troubleshooting determined it was the wet end. I couldn't get the impeller free from the motor shaft. Took it to a local pool store and they very kindly removed the impeller, cleaned up the motor shaft and gave lots of good advice at no charge. As there parts prices were only a little higher then on the internet I bought them there in exchange for the good service I'd received.
    Question: The impeller they sold me was a 1 hp impeller, the old one was a 3/4 hp. I've installed and everything seems to work fine, but I wondering if there could be any long term consequences
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    22,549
    Re: Pump impeller size?
    On a 1½ hp motor, using a 1 hp impeller will increase your flow a little over the old impeller but the motor will be fine with it. Your amp draw will go up a little with the new impeller but not much.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    May 2009
    Youngsville NC
    395
    As long as your motor SFHP is equal or larger than the HP for the impeller - you'll be fine. Not as efficient as possible - but it shouldn't blow up on you either.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Thanks, it's kind of what I thought which is why I went ahead and put it together.
    Brings up another question though. Since the motor has been changed out at some time in the past I have no pump data placard, I kinda guessed based upon the standard Hayward powerflo pump info. With the new impeller do you have any idea what my flow should be now? I have a Hayward SwimPro SW256T which is rated at 80 gpm. If the motor ever dies I plan on going to a two speed but until then I'll use what I've got as long as it won't damage something.
    Dan D
    22,549
    Give us your filter pressure and suction head. If you don't know the suction head, describe your suction piping and equipment.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I'll have to ask the question later, right now this pump/filter is not setup, it's a project for this fall/winter.
    Dan D
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Since your sand filter is rated at 1600gph (27 gpm) the pump might be over sized enough to cause channeling. If it does channel you could eliminate that problem by installing a valve on the pump discharge and close it off some to reduce the flow.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Thanks, that is one of my concerns especially since the impeller has been upgraded. Once I have it up and running next year I'll post back with picture's & psi numbers so somebody can give me good numbers. Does the valve have to be between the pump and the filter? Seems that a valve between the filter & return would restrict flow through the filter but leave full flow available for backwash and waste. I was planning to hard plumb and put valves at the skimmer & return with disconnects so this would eliminate and additional valve if this would work.
    Dan D
    22,549
    A valve on the discharge will work fine. It'll raise your filter pressure but limit the flow through the filter.
