Thread: begin cya
    begin cya
    is there a way, test or procedure to learn how to measure cya readings? i would assume someone has an idea of how to use water and maybe a small pre measured amount of some form of cya in a tube or measuring cup to get a base reading so beginners know how and what to look for and what the final reading should look like.
    21X41, 30,000, ig, vinyl,48sf de, 1hp hayward super pump, 2" piping, 2 skimmers, 1 main inlet, 2 return, built in 1988, no enclosure, lots of trees around, direct sun. Thanks in advance to all who have answered my questions.
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: begin cya
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    22,551
    Re: begin cya
    Order the test solution from tftestkits and that helps tune your testing procedure.
    Re: begin cya
    that link tells you how to do it and show it but it doesn't tell you how to get a predetermined amount so you can evaluate your results under different light levels so you can make adjustments in reading if you have to do without the recommended indirect sunlight
    Aug 2010
    Boston, MA
    176
    Re: begin cya
    The test solution Bama mentioned does provide a predetermined result (50 ppm).
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
