nopool
0
Many pump motors have a plastic cap on the back end that exposes the end of the shaft. The shaft may have a slot in it that allows you to stick a large screwdriver in it and you can spin it. If it is not locked up spin it in the right direction and let someone else hit the switch quickly and see if it starts. If it does it is most likely that capacitor. If any of your friends or neighbors an a/c guys they can check a capacitor for you. If it does start when you do that you can let it run till you can get the capacitor.
If the motor is stuck, check good to make sure it's not a stick or something that got by the basket and is blocking the impeller.
This worked really well for me. I used pliers to turn the shaft and my wife flipped the switch - it took a couple of turns but then rolled right into action
