Page 1 of 3 123 LastLast
Results 1 to 20 of 45
Thread: pool pump makes humming noise and does not pump
    Apr 2011
    Houston, TX, USA
    105
    hey guys,
    i came back from vacation the other day and noticed that my pool pump is no longer working. when i turn it on, it makes this low humming noise and nothing seems to move. this is very similar to the noise i used to hear when our garbage disposal was stuck. The garbage disposal could just be turned once and it started again. is that something i can do with the pool pump as well and make it run?
    if i had to replace it, any suggestions for a good pool pump that won't break the bank?
    Current pump is pretty old and is
    Century Centurion model
    switchless motor with no governor
    1hp
    RPM 3450
    14500 gallon plaster pool (replastered in May 2009) : 32ft.L x 4ft.D x 14ft.W
    Pentair FNS Plus 48 sqft DE filter
    Polaris 280 at 2hrs per day (retired now) & Aquabot T-Jet Turbo used as needed
    Circupool RJ30 SWG set at 80% output & Pentair SuperFlo 1hp 2speed running 6-8 hrs/day in the summer
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: pool pump makes humming noise and does not pump
    Kill the power, open the strainer, pull the basket, and see if you can't spin the impeller with your fingers.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    It could be the start capacitor. It's an easy fix. Do a youtube search on replacing start capacitor on pool pump. Several come up.
    Apr 2011
    Houston, TX, USA
    105
    thanks guys. will try spinning the impeller and see if the capacitor is the issue.
    Many pump motors have a plastic cap on the back end that exposes the end of the shaft. The shaft may have a slot in it that allows you to stick a large screwdriver in it and you can spin it. If it is not locked up spin it in the right direction and let someone else hit the switch quickly and see if it starts. If it does it is most likely that capacitor. If any of your friends or neighbors an a/c guys they can check a capacitor for you. If it does start when you do that you can let it run till you can get the capacitor.
    If the motor is stuck, check good to make sure it's not a stick or something that got by the basket and is blocking the impeller.
    10,800 gallons Gunite/Plaster
    Hayward 244t 24" Sand Filter with Zeo
    1 1/2 HP Challenger
    Digital Pool Pilot DIG-220 SC-48
    Located in NOLA
    Apr 2011
    Houston, TX, USA
    105
    i couldn't reach the impeller from the strainer lid, so i disassembled the front of the motor and exposed the impeller. i was able to *easily* spin the impeller in both directions, clockwise and counterclockwise.
    I looked online and found some good articles like this one on how to proceed. will try that this weekend. http://www.inyopools.com/HowToPage/how_ ... citor.aspx
    in the meantime, my salt water pool is now green
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Does sound like the capacitor. I just rebuilt the wet end of a pump, it wouldn't turn free until I disconnected the pump housing from the motor.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Apr 2011
    Houston, TX, USA
    105
    i got the capacitor out this weekend and Leslie's didn't have a replacement for it (the kid that was at the counter could not find a single capacitor to even order). after some searching, warehouse pool supply said they would test my capacitor and have in stock to replace it. Would any generic 25MFD work here, or i have to get the exact replacement?
    22,550
    A generic that will fit in the place will work fine.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Try appliance parts stores they usually sell start and run capacitors for a variety of motors, also HVAC contractors. Take it with you to the store and I'll bet the can match it up. MFD, voltage and physical size are going to be your primary parameters.
    Dan D
    Apr 2011
    Houston, TX, USA
    105
    thanks guys!
    If you have Grainger supply near you they may have it too. I have always found something there that would work electrically but sometimes physically to big to fit under the cap. I have always had good luck with electric motor repair shops and the A/C supply houses.
    1 1/2 HP Challenger
    Located in NOLA
    Apr 2011
    Houston, TX, USA
    105
    hey guys, everyone here was spot on. i bought a capacitor for $20 and that fixed my pump.
    So the pump is working perfectly now, but i had also taken off the screws that expose the impeller. when i put them back on last night, i noticed my pump is leaking a little bit of water.
    I am sure i tighten them pretty week. should i be putting some silicone or plumpers thread anywhere on the screws or the impeller assemply to prevent this?
    thanks!!!
    22,550
    You should lube the o-ring before you put it back together. Maybe a little tightening will stop it. If not then take it back apart and check and lube the o-ring.
    Nov 2007
    Austin, TX
    69
    Be sure not to over tighten the bolts. If all of the seals/o-rings are in good shape and lubed, it should not take a lot of torque to avoid leaking. If the bolts screw into threaded inserts embedded in the plastic body, they are very easy to pull out.
    My Pool
    15k Gal Gunite Pool w/8 ft Spa w/Spillover
    Hayward DE Filter + DE Separation Tank
    Legend Sweep, Pentair Gas Heater
    Stenner Metering Pump for Liquid Chlorine Injection (15 gallon tank)
    Apr 2011
    Houston, TX, USA
    105
    i may have overtighten one of the bolts yesterday. should i just go and get a new bolt, or am i screwed on that?
    also, what kind of lube should i use for the rings?
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    If you have an insert come loose sometimes you can enlarge the hole and put the insert back in with JB Weld. Just be sure the insert is below the mating surface and the surface is smooth. We've done this on the copiers I work on, usually as a temp fix until we can get the part in for a proper fix, it's usually a pretty strong fix if you let the JB Weld cure properly.
    Dan D
    Jun 2012
    Houston, TX
    39
    Walked by my pool to get into my car and go to work this morning and noticed the pump wasn't running (Centurion B855 2HP), but there was a hum. Within minutes I find this thread (once again TFP to the rescue). I guess I know what I'm doing tonight...
    I would not suggest using your hand to spin the impeller from inside the basket when the pump is making humming noise and not running. I don't normally post messages but I have gotten a lot of good info from this site and I didn't want anyone to get hurt. I decided to spin my impeller from the pipe that goes to the motor from the strainer lid (open up the lid and remove the basket) and see if it would kick on. I got this idea from reading the info below and watching the suggested YouTube videos. It started my pump up but my hand got sucked up into the pipe/impeller and was pretty cut up and bruised.
    Again, I would not suggest using your hand to spin the impeller inside the basket. When it starts, it sucks immediately so if you do this you need to hold tightly to whatever you're using to spin it and DO NOT DO THIS WITH YOUR FINGERS. That being said, it did start my pool pump running again which confirmed that I probably need a new capacitor. This did not work until I filled the strainer area up with water. It never really fills up with water but the pipe going to the impeller needs water for this to work and I let it run back into the pipes leading to the pool for about a minute. I only have a 1 HP pump so I can't imagine what would have happened had the suction been stronger.
    Another note is if it is your capacitor, when you turn off the pool pump you will need to spin the impeller again to start it. It's a temporary and dangerous fix if done the way I did it. I did see some other suggestions below that sound a lot safer.
  20. Back To Top    #20
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Lpeterso15
    Wow, I hope you hand is okay!
    That is why the first responder (Richard320) said:
    Quote Originally Posted by Richard320
