Results 1 to 7 of 7
Thread: pool floats with inground pool?
    Jun 2011
    Nj
    57
    why is it we dont use floats with inground pools?
    would water runoff off the tarp be better then it filling up with water?
    total noob question, just curious
    11,000 gal inground fiberglass pool
    Aquarite SWG system
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: pool floats with inground pool?
    You can certainly use one, if you'd like. It won't hurt anything and can help you keep the cover water free. However, possibly the main reason of having a float under an A/G pool is to keep the weight of the water on the cover from pulling in the top of the wall (which which you have no issue)
    Luv& Luk
    -Ted
    Jun 2011
    Nj
    57
    would it be better tho to have a float?
    i live in a very vegitative area, pines and decidous, which will drop alot of leaves
    i would think it would keep them from getting in the depression and thus the pool water
    Aquarite SWG system
    Apr 2011
    Lynchburg VA
    393
    If I were going to cover my pool with a solid cover instead of the lock n loo that I have I would use the float. It will keep water and leaves from gathering in the center of the cover pushing them to the edges of the pool where they will be easier to clean off.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Diver's Avatar
    May 2011
    South of Boston
    450
    you would have to have the cover stretched pretty tight in order to all the water to run off. if there is any slack then the water would start collecting there and before you know it it will pull the cover down to the water level in the pool.
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    Jun 2011
    Nj
    57
    i have a fence around the pool
    i planned on tying the tarp to the posts
    Aquarite SWG system
    Diver's Avatar
    May 2011
    South of Boston
    450
    Quote Originally Posted by *ryan
    unless it's absolutely smooth with no sagging, the water will find the lower spot, accumulate there and collapse the fence if it doesn't, then the snow&ice will since snow&ice will stick to the tarp even if it's perfectly stretched.
    i toyed with a similar idea last winter and decided it won't work. but i hope i'm wrong and you post back in the spring telling us how awesome it worked!
