Thread: Do-it-yourself calcium removal?
    Hi all, I have very hard water in my region. This company was on the news last year: http://www.calsaway.com/arizona_pool..._the_press.php If I recall, the news showed them putting something in that precipitated most of the calcium to the bottom off the pool, then sucked it out via hoses to filter screens on a truck, then they returned the clear water back into the pool.
    Does anyone know of any DIY method to remove decent amounts of calcium from pool water?
    Intex Sequoia Spirit above ground 16' round pool, 5,000 gals. ,vinyl liner.
    Intex Saltwater Chlorine generator/pump/filter combo system
    Test kit: TF-100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,768
    Re: Do-it-yourself calcium removal?
    Nope.
    Calsaway does reverse osmosis. It's more complicated than this, but essentially think of a super-fine screen. It filters out everything that isn't a water molecule. Everything. Calcium, salt, metals, cya, chlorine...
    Most of your bottled drinking waters (maybe all of them) have water purified by reverse osmosis, and then they add minerals back to make it taste better!
    For the homeowner, it's drain and refill. Rainwater is good, as it has no calcium in it!
    Feb 2008
    Denton, TX
    5,061
    Those reverse osmosis companies do a pretty good job. I like to think of it as dialysis for your pool. Not sure on pricing, but they are quite effective.
    Oct 2007
    Valrico, FL
    540
    Water softener resins also work. Takes time to get a low CH level, and then you have to soften your fill water. I did it on my pool. Went from a high of 600 ppm CH down to 280 ppm.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    It could be an Oxalic acid treatment.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
