Thread: cleaning a hayward de-3600
    Apr 2010
    Central NJ
    227
    I want to clean my de-3600 filter, but after reading the sticking aboutnthe D-ring, I'm not sure if I should. Should I be concerned? What should I do?
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: cleaning a hayward de-3600
    sorry, can't help you...
    Dec 2010
    San Diego, CA
    1,137
    There's a replacment for the o-ring but It has a whole new clamp assembly so the first time it's spendy - I think like around 130 or so? After that you can get the new o-ring only. The sticky should have the info on this
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
