Thread: showing high temp sc60
    Auto pilot just started showing a pool temp of over 100 degrees when in fact the water is about 80. I have turn the unit of and back on but still showing over 100. also it after turning off and on it show to add 300 lbs of salt but within about 5 minutes it show 3300 salt level. the unit is about 4 years old with about 4 months each year of use. Thanks
    45000 vinyl IG - salt water Pool Pilot 60 - 24 by 48 - DE hayward - 2 hp pump
    Ft Lauderdale, Florida
    1,455
    Re: showing high temp sc60
    Sounds like a bad tri-sensor connection. Check to make sure it is not loose or that the connector pins have not been bent or damaged. Also, if you wiggle the connector and it corrects the temp reading, then the connector is too loose.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
