Results 1 to 13 of 13
Thread: Anyone close pool without draining at all? (Cold Climate)
    First year with this pool. An acquaintance who has worked on pools for a living for a long time says I don't need to drain below skimmer/returns to winterize... mentioned a plug I could buy to thread into the skimmer that would aid in blowing out as well as accommodating ice expansion; blow out & plug skimmer/returns; no antifreeze.
    Does anyone else do this? I'm in Kansas, things freeze up pretty good here. Times are lean and water is expensive to just drain out.
    I know when we looked at the house the first time, before the pool was opened, whoever had closed the pool had lowered the water.
    Thanks for any help!
    25,000 gallon 18x36 vinyl inground, sand filter, been doing this a few years now and feel like I have a decent handle on it.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,106
    Re: Anyone close pool without draining at all? (Cold Climate
    We use something like this in our pool. We never add antifreeze as we're able to disconnect the pipes and allow all the water drain out.
    http://www.intheswim.com/Pool-Openin...mer-Guard-Kit/
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Up here in Minnesota, I drain ~6 inches below the skimmer (about the same below my return). I disconnect my pipes from skimmer and return. I then blow the pipes that go back to my equipment out and cap them with rubber caps. I do not take chances...a little water next spring is worth it.
    South Central NJ
    3,192
    The only in ground pools that I drain are those with tile. Skimmers get either Ultra Gizmos or blow through extentions. Return lines get appropriately sized rubber plugs that expand with a wing nut.
    Above grounds may either drain to the skimmer mouth or block the skimmer with a plate.
    Scott
    Owner of - PoolGuyNJ LLC
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Inground vinyl/fiberglass pool solid safetycover, i drop water level bout an inch fom middle of skimmer..why? NO IDEA lol, but every year when they open they are ann inch higher
    Solid tarp cover, bottom of skimmer, weight of snow forces water in pool up
    Mesh... tell the homeowner bottom of skimmer, and if they didnt forget how to turn the skimmer off from the last time i told them then i say 2 inches below skimmer ...usually still high when we open
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    u can add antifreeze in through the top once the line is blownout...cant hurt right?
    COMPANY INFO BELOW
    South Central NJ
    3,192
    Most solid safety covers are sewn through. A little water will weep in.
    Pools with tile lines should also get a step pump. This will drain off any water that gets near the tile line such as during snow load conditions.
    It is placed on the step of the swim out, if the pool has one or on the 1st or 2nd shallow end step. I prefer the swim out because it's step is usually an inch or so lower. If it is going on the 2nd shallow end step, I look for something to raise it up some.
    I can count on one hand the number of times I needed to add anti-freeze. It has always been in flooded suction situations. For those that like there anyway, always use biodegradable, never automotive.
    Scott
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    DistantHorizon,
    If you have a looploc cover or one that allows water through, you can drain 6" below the skimmers, close them up, add a little antifreeze within the skimmer and by the time spring arrives, you will have water near the entrance of your skimmer, from my past experiences... Had to add very little water by spring time. Snow fills it back up. All pipes are blown out prior to plugging them.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Sorry, I failed to mention I will be purchasing a cheap winter cover. Previous homeowner said the cover we have now was purchased too small, and I remember it was falling in on one of the occasions when we looked at the house before purchase.
    Pretty sure the skimmer thing the pool-guy-acquaintance suggested was like the one Leebo links to in post #2.
    South Central NJ
    3,192
    A tarp cover needs a 2-1/2 foot overlap on all sides.
    Scott
    When my pool acquaintance mentioned not draining, he said something about elbows for returns I could get, but I didn't quite catch it. When I posted, I thought someone here would mention them.
    Today while looking through the big tub of pool ****, I had an "aha" moment when I found this stuff:
    So apparently this pool HAS been closed without draining before. I already have 3 little "snorkels" to thread into returns, with plugs to go on the top, above the water level. Also have skimmer gizmo with plug in the top for blowing out through said gizmo. Assuming the straight pipe was "poor man's skimmer gimzo"?
    Ordering my cover tomorrow, and going to close pool next weekend. Checked water temperature today, it is down to 62 degrees.
    Sep 2010
    Winnipeg, MB
    5
    That snorkle idea seems BRILLIANT. Supprised I haven't seen it anywhere else.
    Should make blowing out/plugging far easier if you don't drain below the returns, as it essentially moves the returns up above the water level.
    Also makes it easier to add antifreeze, as the 90 prevents the need for a funnel.
    Pool: 16x32 inground (2011) Experience: Some - With a previous above ground, learning with my brandnew pool
    South Central NJ
    3,192
    The only devices there I use are the rubber winter plugs and the Alden Leeds Blow Through Extention with it's shown winter plug. This is my preferred device with Ultra Gizmos coming in a close second for winterizing in ground pool skimmers.
    The PVC snorkels may present issues with pool covers.
    Properly sealed lines don't need antifreeze. If air can't get out when it's sealed, water can't get in. IMO, adding antifreeze is wasted money. You would need enough to get to the frost line. That can be quite a bit with a 50' line and 2" pipe.
    Scott
