Thread: Leaking Pump SP3010X15A
    Jun 2011
    New Smyrna Beach, FL
    31
    So I have a neighbor who is a single mom with two kids. Her Hayward pump SP3010X15A is leaking. A causing a swamp between our house and hers. It looked as though the seal was leaking. She tells me that she cannot afford to have someone out to fix it. I volunteered to try and fix the leak. Went and bought a new seal and gasket. Installed it this morning and it still leaks. Has anybody ever replaced one of these seals. I followed the manual but just cannot get it to stop leaking. What did I miss????
    1: 10,000 gals in the ground plaster, Hayward pump SP2715X20 2hp
    2: Aqua Rite Electronic Chlorine Generator / T-Cell-15, Hayward Pro-Grid DE Filter Model DE3620
    3: AquaCal Heat Pump, Astrlite SP0580S Under Water Light
    4: Port PolarisCaretaker, TFTestKit-100
    22,542
    Re: Leaking Pump SP3010X15A
    Did you inspect the seal plate to make sure it isn't cracked? That's common when the seal doesn't stop the leak.
    Did you replace and lube the housing o-ring?
    Also, remove, clean and lube the drain plug(s) (there may be more than one).
    Inspect the entire pump to acertain where the leak is coming from exactly.
    Jun 2011
    31
    Thanks. I am going out to work on it again today. I did lube everthing and checked for cracks. Cannt see any but at my age I could be missing them.
    22,542
    Make sure the ceramic and carbon faces are facing each other and are extremely clean and smooth.
    Jun 2011
    31
    Thanks to all I finally found a crack in it.
