Hayward SWG says low salt, wrong?
Jun 10, 2008
25
Hello-
My brother has a hayward turbocell with the goldline controller box. It was installed before he bought the house and seemed to work slightly from time to time (cell was shot).
He put in a new cell yesterday (T-cell-15), but the controller screen displays "2500" and the low salt light flashes (says flashing indicates that cell is operating at reduced levels, due to the low salt condition).
The old cell AND the new cell installed both have the computer screen showing 2500. However, the LPS tested his water and said he has 3800 ppm salt.
Any idea why the pool store says he has plenty of salt, but the system thinks otherwise? We thought maybe the old cell was giving bad readings - - but the new cell is still showing the same thing.
Thanks for your help!
dmdrums
I have the same unit "Aqua-Rite" for about ~6.5yrs I think. At ~6yrs I had same issue, and then it gave "inspect cell". I ended up replacing both the cell and the flow switch.
First try holding down the small black button for 3-5 seconds on the controller (next to the display).
dalman-
I was able to clear the "inspect cell" message by holding down the "diag" button for a few seconds. I'm just confused why the controller keeps saying 2500 and indicating low salt. I had the pool store test salt level AGAIN today and it is still 3800.
Does it take a while after replacing a cell before this number is updated on the controller?
Have a great night,
dmdrums
it should not take long to display the reading;
I would turn/ flip the main switch off on the controller Auto/Super C/ Off, if possible cut the power to controller.
( I have a switch box that turns off power to timer and controller) . leave off for a few minutes and turn power to box back on, then flip controller main switch up to Auto.
I have to do this sometimes when adding salt, and forget to flip the main controller switch down to OFF position. It
seems to get stuck (in this case it was stuck with hight salt).
I hope this helps. I would not know what to check after that.
Just wanted everyone to know it has fixed itself.
Took a day or so and then the controller changed from 2500 to 3800.
The reading on the screen is the same as the pool store!
Perfect!
dmdrums
