Results 1 to 8 of 8
Thread: Using Water Bags On Loop Loc Safety Cover?
    Hey folks,
    I have a mesh safety cover from Loop Loc for my in-ground 18x36 pool. At the end of last season I put in a new stone patio around the pool, but haven't yet re-installed the anchors to attach the cover to the ground. I've got a lot going on right now and don't plan to put the anchors in this season. I'd still like to have a cover for the winter though (however in this case it won't be for safety, but rather for cleaner/easier opening). Any reason why I couldn't purchase those water bags and use it with my cover? Should be fine, right?
    Thanks!
    18 X 36 In-Ground Vinyl Pool, Hayward 1 HP SuperPump, Hayward SP270T 350lb Sand Filter, CompuPool CPSC48 Salt Chlorine Generator, Hayward H400FDN 400 BTU Natural Gas Heater, 2 returns, 1 skimmer, No Main Drain
    22,553
    Re: Using Water Bags On Loop Loc Safety Cover?
    As long as you and everyone else understands that it's not a safety cover anymore and you have an alternate way to make it safe, it should be fine.
    Cool thanks!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I don't think it will work. A Loop-Loc isn't big enough to be used like a standard cover. The cover needs to lay down on the water, and then up the pool wall and still have enough remaining fabric for the water bags to sit on. Unless yours was made longer than normal, it isn't going to work. The weight of the wet cover will drag it into the pool.
    South Central NJ
    3,192
    JohnT is 100% correct. Tarp covers need at least a 2-1/2 foot overlap on all sides. Once the leaves start falling, they will land on the cover, get wet, and weigh it down. Add a snow load and a new swamp is born.
    Scott
    Owner of - PoolGuyNJ LLC
    Alright...thanks guys. I'll make a decision then...install the anchors or buy a winter cover. I'm so hesitant to drill 20 holes in the new stone patio. But of course the safety factor is there.
    Thanks again
    South Central NJ
    3,192
    Rent a good sized hammer drill and a 3/4" bit. A Hilti TE 46 up to a TE 70 is ideal. If you're buying a drill, a Bosch Bulldog is relatively reasonably priced.
    Use new anchors.
    Try to stay out of the grout lines. They won't hold the anchor casing well.
    Scott
    If the stones are loose set, then you need the anchor-in-pipe system.
    Instead of using a hammer drill, you might want to use a diamond bit hole saw (core drill) to reduce the risk of cracking the stones.
    Alternatively, you could put stakes outside of the deck and extend the straps if there is somewhere outside of the deck to put the anchors.
    Support the site
