Thread: hayward dial a flo sp-732
    Apr 2010
    Central NJ
    227
    I have an air leak on a hayward sp-732. The air leak would happen no matter what position the valvle was in, but after removing it and re-installing it, now I only get it in the off position. Is there a way to fix it?
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    22,550
    Re: hayward dial a flo sp-732
    It's obviously on the suction of the pump.
    You can rebuild those valves. Here's a parts diagram. Looks like you'll need items 5 & 6 (and maybe 3 if yours is weak.).
    Apr 2010
    Central NJ
    227
    For #5, there's two of them, SPX0733Z3A and SPX0733Z2A, I guess I would need the latter, correct?
    Does it matter that the parts say 733? Would it fit a 732?
    22,550
    Unless you lose or damage the screws you shouldn't need them. So yes! The parts are for both a 732 and 733 so they'll fit.
