Results 1 to 8 of 8
Thread: Wall liner floating from ground water. What to do?
    Due to all of the rain tropical storm Lee has dropped, I now have water behind the liner on my walls. It doesn't appear too bad at this point. It is worse is one of the corners in the shallow end. Floors look good. It appears to start mostly at the water level and goes down about a foot below water level being a small bulge of about an inch. Corners are a little worse. Should I do anything or will it go back on its own? There is a well built under the pool and I have pumped it out a few minutes ago. Liner is about 4 months old. Here are some pics I just took. There seems to be a lot of water behind the liner on the walls from what I can tell by looking and touching the liner.
    31,000G IG vinyl 20X40 True L. Hayward 1.5 superpump, Autopilot Pool Pilot Digital SWG, Hayward Model S244T 300lb sand filter, TF100 kit
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Wall liner floating from ground water. What to do?
    As the ground water recedes your liner will fall back into place, but you may have some wrinkling. Some of the pool service guys can give a little more information on dealing with the wrinkles.
    Love TFP? Become a
    TFP Supporter!
    I kinda figured it would go back to normal on its own, but didn't know if I should do anything in the meantime. The wrinkles are really what I am concerned about. I really would like to minimize or end up with none if at all possible. I'd hate to have a wrinkled up 4 month old liner.
    If you can fill the pool up a few inches, that would help.
    Support the site
    Got the hose in it now.
    WHEW!!!! I've been draining the well under the pool on and off and the liner is back in place with no wrinkles. I guess I need to start draining the well more after it rains.
    30,414
    You need to do that during the rains rather than after. Use that pump as a preventative. If you wait until the rains have stopped you will likely float the liner again and, sooner or later, it will not go back in place.
    22,544
    The pump in the well point should be on a float and should be on before or at the very beginning of a rain event.
