Thread: Pump trouble
    Columbia, SC
    22
    Pump trouble
    I had to remove my pump from the strainer housing to replace a gasket. I had no problems whatsoever initially. I removed the four bolts changed the gasket put the pump back in place and tightened the bolts without incident. I turned the power back on and when I hit the on switch for the pump it just buzzed, nothing else. So the buzz indicates it's getting power, but nothing's happening. I tried running it unattached from the strainer housing and it still just buzzes, nothing else. Any ideas would be appreciated.
    20K gal, vinyl, 3/4 HP pump, Hayward sand filter
    Dec 2010
    San Diego, CA
    1,137
    Re: Pump trouble
    Did you check to see that the wires didn't come loose from moving the motor around?
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Columbia, SC
    22
    Re: Pump trouble
    Thanks Carlscan 26. Turns out there was something small in the (impellor?) That was preventing it from turning. So the pump is working unfortunately the new gasket didn't stop the water from coming out from underneath the pump. There's a square hole underneath the pump and water is coming out of there. Any thoughts on that would also be appreciated.
    Re: Pump trouble
    You need to replace the seal assembly. If it's the Hayward SuperPump, then you need part number SPX1600Z2.
    http://www.hayward-pool.com/pdf/Parts%2 ... 20Pump.pdf
    http://www.hayward-pool.com/pdf/manuals/Manual113.pdf
    Support the site
