Thread: Color Logic Light won't change color
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    anyone know why? It's stuck on one color and won't change. There are 2 lights in the pool. Only having problem with one. The other changes color.
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Re: Color Logic Light won't change color
    when I removed the light from the pool there was a little bit of water and condensation in the light fixture. is this normal? could this be causing the light not to change color?
    Thanks.
    Aug 2011
    Manteca Ca.
    8
    Check your grounds for the lights, I had the same problem and found I had loose grounds. Tightened up the grounds and fixed the problem.
    15'X48" cheapo Intex metal frame pool. 4400 gallons.
    Cartridge filter
    The only thing I could find about the pump is it says 1000 gallon filter pump.
    Mar 2007
    Coastalish 'down easter'
    4,160
    No there shouldn't be any moisture in the light fixture. Let it dry , replace the sealing gasket and turn the lights on for a minute and then off for exactly! 12 seconds. This should re-sync them.
    Luv& Luk
    -Ted
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Thanks for the replies guys. I think the lights are now insync but hard to tell in the daytime. I might just send this light back and get a new one. It's only a few months old. I think it is still under warranty.
