Thread: best time to change sand
    Jul 2008
    Bucyrus, Ohio
    108
    I need to change my sand after this season. Wondering if its better to do it when I close this fall and leave no sand in the filter or should i leave it and do it in the spring?
    Thanks
    Overwhelmed
    Pool size: 15' X 48" AG vinyl liner, 5300 gallons, Hayward S166T filter and 1hp pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: best time to change sand
    I don't know that leaving it empty would hurt anything, but it sure would be nice to have it ready when you open up in spring.
    Essential Links:
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by jshinklin
    Why? Are you having trouble filtering? Not much evidence for sand "wearing out". See this post: http://www.troublefreepool.com/sand-...9.html#p247326
    As long as you drain the water, it shouldn't matter. It won't hurt the filter either way, unless you move it carelessly with the sand in, or wind blows the empty filter around during winter.
