Results 1 to 10 of 10
Thread: Advice for take down and preparing for winter storage
    Time to put the pool away for the winter. After drawing the water down in prep for the hurricane, then getting 7 inches of rain from it plus lots of evergreen needle debris blown into the pool it is time to take it down for the winter since the water temps just aren't coming back up sufficiently.
    This is my first year with an ultra frame and wanted to garner any advice or experiences you have had in disassembling and storing same over the winter. Have started to empty, all but a few inches left what remains below the hose outlet. I am basically doing this by myself so trying to lift and maneuver the liner to get the last few inches of water to discharge at the hose outlet doesn't appear to be practical. Also have a bunch of small evergreen needles in the bottom that the crappy intex hose vacuum thing could never suck up from day one so I need to get all of that out too. If I remove sections of the frame to maneuver the liner to get the water over to the hose outlet then in theory the liner may not dry unless I put the frame back up. Thinking the best solution may be a small sump pump to get the majority of the remaining water out them maybe shop vac the rest out. Am I thinking this through correctly or am I missing an easy way to do this?
    Was also thinking that before it gets packed away I should give the liner a quick wipedown with bleach solution, to make sure it is super clean before putting it away. Any other advice?
    Almost makes me want to dish out the center grade next year and install some sort of main center drain with a plug which would make all of this a non issue. Has anyone ever done/tried installing a center drain in an ultra? I could easily gravity drain the pool since when i built the pad I leveled the low end up with a retaining wall instead of digging down the high side. The wall only goes around the pool maybe 2/3-rds of the way so the high side of the pad is basically at grade. I know, building up a pad is not recommended... but for where I wanted to put the pool I didn't want to install a fence around the pool. The grade 3-feet around the pool had to be down 48" or more from the top rail to forgo the fence and had to be clear of ANY objects that could be used to step on and get into the pool. So, raising the low side made the most sense since the wall could be placed inside of that 3-foot clear zone since the grade droped off further from the wall. If I had dug the pool in, the retaining wall would have had to be at least 3 feet from the outside of the pool then we would have had to build more steps down (which would have had to be outside of the clear zone) to the pad and theoretically push the whole thing even further away from the deck and done alot more excavation. Plus when the pool is down I can use the partial raised patio for other things and don't have to try and mow around a fence. Pool has been rock solid, no settling at all. Here's a picture from when it was almost complete, pool was not filled yet and i still had to cut off the geogrid sticking out of the wall.
    Also, how do you all store your liners? I saved the box so I can put it in there or maybe a large rubbermaid container one for the legs/rails and a second one for the liner? I did remove the thru the wall inlet/outlet and definately want to upgrade to standard parts before next season. That will be the subject of another topic.
    Thanks in advance for any advice.
    Love TFP!! Have learned tons so far and have lots of learning still to do and dumb questions to ask. You guys/gals rock!
    -Melissa
    Intex Ultra 16'x48"
    Intex SWG
    Intex 2650 sand filter
    Jun 2011
    Cape Girardeau, Mo
    125
    Re: Advice for take down and preparing for winter storage
    I will be leaving mine up for the 3rd year and yes it does freeze here i have never had a problem just leaving it up and using a cover. But if you must take it down i would probably store it in a metal trash can i have heard stories of people have the liner destroyed over the winter by mice.
    Steve Frakes
    15' X 48'' Intex Metal Frame
    Intex Sand Filter 16'' 2650 GPH
    Taylor K-2006 Test Kit
    BBB and Borated
    homeschoolmoxy's Avatar
    Jul 2011
    Northern NY
    29
    Quote Originally Posted by fsteve65
    You are pretty lucky that your pool is still intact. We left our frame style pool up a few years back and it froze into one huge ice cube. During a January thaw it burst open on one side and split all the way from top to bottom. It was quite a mess
    27 foot AG vinyl pool (17100 gallon) - Sand Dollar Filter 1.5 hp 2 speed pump
    TFTestkit
    I have been taking my pool down for seven years. I originally tried to drain from that side plug the first year. Took forever to drain. Now I siphon out with the vacuum hose that comes with my vacuum and the hose is so much bigger so it doesn't take but maybe a day and a half. I do use a sump pump for the remainder and also the shop vac to get the last bit out. I always take my water hose and spray all the gunk out that has built up in the top of liner, and then with a bucket of water with something like Pinesol or Mr. Clean and a mop to finish up the job. Then let dry in the sun; and last I will go over with an old towel and make absolutely sure I have it completely dry before packing away. We have a large plastic container that we store ours in, and we have never had any evidence of critters bothering it.
    18x52 Ultra Frame with 1600 gph sand filter and intex skimmer
    I store the liner and soft pool stuff (deflated rafts, etc) in one tall wheeled trash can. The poles in another. Shop around for the trash cans if you go tis route. I bought for $29.00 each at one ig box store vut similar sized ones were $60 at a different big box.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Oh yeah, your pool site looks great!
    docchop1's Avatar
    Apr 2011
    Southern Indiana
    61
    Is it necessary to protect the stored liner from freezing?
    Intex 15x48, Intex Saltwater Chlorine Generator, Intex 14" Sand Filter, TF-100 unicorn eating spaghetti while riding a unicycle on a high wire during a storm edition test kit,
    http://tftestkits.net
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    I empty mine out, vacum the last of the water out with shop vac. Put every other leg up on a lawn chair, spray off the bottom and let the whole thing dry off. Roll it up and put it in a trash can with a lid.
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Just finished putting mine away for the season....it is really sad....anyway once empty, which I use a garden hose, then sump pump then shop vac, I turn mine over inside my shed (propped up) to let dry out, I then pick a nice day lay it out on the lawn to get real nice and warm and blow any moisture away with my blower vac, roll up and put in a 42 gallon bag and store down stairs, next year I will wipe down with a good bleach/water mix b4 filling.
    Intex 16x48 Ultra Frame
    5100 gallons
    Intex Sand Filter and Pump
    BBB Bliss Baby!
    Jul 2014
    woodland
    1
    Quote Originally Posted by ladylion View Post
    Helpful hint..after clean and dry, sprinkle generously with baking soda. This absorb any moisture left behind and prevent the pool from sticking together when its time to put it back up next season.
