Results 1 to 14 of 14
Thread: Closing a pool with a mesh safety cover
    norbie's Avatar
    Aug 2007
    Massachusetts
    39
    Hi All,
    I bought a Loop-Loc mesh cover last year and would like some info on how to close my pool. I usually close my inground 16x32 pool around the end of September. I'm new to the mesh cover. I use Bromine and was wondering if I do anything different as far as closing my pool. I've seen kits specifically for mesh covers. Is this an option or do I just adjust my chemicals?
    Any information would be greatly appreciated and thank you in advance
    Norbert
    23,000 Gallons; 16 X 32 w/ 4 X 8 Steps; Vinyl Liner; Hayward EC65A DE Filter; Hayward 2607X10 1 HP Pump; Hayward CL200 In-Line Chlorinator;
    Bromine; LOOP-LOC Winter Mesh Safety Cover; Aquabot Supreme Automatic Robotic Cleaner;
    Re: Closing a pool with a mesh safety cover
    With a mesh cover it is important to close fairly late in the season, ideally when the water has gotten below 50 degrees. You also don't lower the water level as much as you might with a solid cover. The mesh cover needs to be able to rest on the surface of the water, which usually means keeping the water level a little higher than you would otherwise.
    You don't do anything special with chemical treatments for a mesh cover, raise to shock level and add algaecide just as with a solid cover.
    norbie's Avatar
    Aug 2007
    Massachusetts
    39
    Thank you
    Norbert
    Apr 2011
    Lynchburg VA
    393
    I have a Loop-Loc Safety cover and there is no way my cover is going to rest on the surface of the pool water unless the pool is filled right to the top edge and overflowing. My cover is stretched TIGHT! Jason, I can only assume you are talking about mesh covers that are not of this type? I do lower my water levels below the skimmer by 2-3 inches and blow out my lines.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Mar 2007
    Coastalish 'down easter'
    4,160
    Quote Originally Posted by BadOleRoss
    Hey Ross
    I think the key word in Jason's response is able. The cover needs to be able to rest on the water's surface when loaded down with snow and ice. If it can't the material can become over=stretched and rip, therefore voids the warranty.
    Luv& Luk
    -Ted
    Apr 2011
    Lynchburg VA
    393
    OIC, I missed that. My cover is "able" to reach the water when my dogs walk out on it to get a drink of water!
    Pool School
    Pool Calculator
    Test Kits
    Toronto, Ontario
    3
    Hi,
    This will be my first time closing my pool. I also have a mesh safety cover.
    When I moved in to my house 2 years ago, the pool was already closed. I noticed in the winter that my cover was stretched very tight when there was snow on it due to the water being very low. I also had issues with my liner floating when opening the pool.
    Last year I had the local pool company close the pool. They didn't drain the water out nearly as much (approx 5 inches below the skimmer). During the winter the cover didn't sag as much, and in the spring the liner was fine.
    The one thing I did notice when opening it was that the mesh had allowed water to seep through, which raised my water level above my skimmer inlet. I'm assuming that this could lead to issues?
    Any help clarifying which way is better would be appreciated.
    Thanks
    Shawn
    Mar 2007
    4,160
    Sorry for the delay in responding
    Taking the water to the level you did is fine. In some areas with heavier rain or snow, you'd want to take a little more water out of the pool for closing (10" of snow =~ 1" water).
    Going over the skimmer mouth top can allow you the water you need to rid yourself of a spring algae problem without having to drop your garden hose in the pool to get it back up to operational level
    Luv& Luk
    -Ted
    I put mine on upside down. Anyone know if this is a problem?
    21000 gal vinyl lined in ground
    36 sq. ft. DE filter with Hayward 1.5hp VSP
    SWG chlorine
    Massachusetts
    May 2017
    Atkinson, NH
    84
    so how low is the water supposed to be?? the pool company said 15-18" below the top. is that too low? should i add water? also, is there a trick to getting the cover on? its so tight....
    New Hampshire, 25K gallons, chlorine, IG, vinyl liner, new Hayward DE filter, new pump, 1 skimmer, paramount in-floor cleaning system with deck-side canister and a by-passed heater the pool store broke.
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,376
    Quote Originally Posted by Dier74 View Post
    Flip it right side up... the "wear" strips are on the bottom & so are the "burst" pads.. upside down with a snow load will "sand" webbing & not protect an inside corner/radius
    May 2017
    RI
    90
    I'm in the same boat here. 1st season with a pool and I just bought a mesh cover that I need to install. I'd like to hear more about how low to drop the water level. Below the skimmers? Above the returns?
    - 41869 Gallon In Ground
    - SWG - Aqua Rite Electronic Chlorine Generator
    - Vinyl-lined
    - Sand Filter- Model unknown
    - Hayward C48K2N143B1 Pump, Century A.O. Smith 1081 3/4HP Booster Pump for Polaris
    May 2017
    Atkinson, NH
    84
    Definitely below the skimmer. Some do below the returns then add more water. Depends on if you are closing it yourself (below the returns is easier to blow out lines I think). It should be about 15Ē below the surface if you have a lot of snow so it can rest on the frozen water so it does not stretch too much. That is what I have gathered here.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    Yes, then you lower it during the winter if it approaches the tile. You donít want ice forming at the tile line. That leads to tile pops.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
