Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
Thread: Drained plaster pool half-way, now what?
  1. Back To Top    #21
    Dec 2010
    San Diego, CA
    1,137
    Re: Drained plaster pool half-way, now what?
    I think that's calcium at 300.
    I doubt the conditioner is really at 0 but it could be. You'll know when you test it yourself - did the kit arrive? It must sound like we are all waiting for Christmas morning vicariously through you...
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
  2. Back To Top    #22
    Aug 2010
    Boston, MA
    176
    How big is the pool? 15 pounds of CYA in, say, 20K gallons would be 90 ppm, which is too much unless you're using an SWG AND it's really 0 now. I share the previous skepticism that it's really 0 - your initial issue sounds exactly like excessive CYA, and draining half the water will only cut that in half, not bring it to 0.
    Don't add ANY stabilizer until you have the kit and can properly test it yourself. Even when you do, I very much doubt 15 pounds would be appropriate.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
  3. Back To Top    #23
    Geo, Look up at the top where it says user control panel. Press that button and enter as much info as you can about your pool and equipment as you can in your signature. It will show up every time you post. Especially the size of the pool. 15 lbs of stabilizer sounds like a lot unless this is a very large pool and the CYA is really zero.
    The test kit should show up soon, let's just get it in hand and do your own testing and we will take I from there. You can only test down to about 15ppm with the kit so you could still have 10ppm or so even if you overflow the tube and still see the dot.
    Based on your own test I would like to add enough cya to get to 30ppm. Add it by puttin it in a sock and hang it in front of a return. Do not put it in the skimmer. Cya takes up to a week to fully disolve and you want to loose as little as possible to back washing. Don't bother to test for cya for a week after adding it. You will begin shocking based on 30ppm cya.
    The more cya the more bleach it is going to take to shock so 30ppm cya will save you some money. If your test comes out higher than 30ppm just go with that level. Have plenty of bleach on hand and if I remember right you have a DE filter, if so have enough for several backwashes. And "Let's get ready to rumble!" it's time to kill some algae and put some overalls on the filter and put it to work getting all the dead stuff out of the pool. It's going to be a marathon but you are going to be happy with the results. Don't forget put your pool info in your sig. We don't want any miscalculation errors.
    10,800 gallons Gunite/Plaster
    Hayward 244t 24" Sand Filter with Zeo
    1 1/2 HP Challenger
    Digital Pool Pilot DIG-220 SC-48
    Located in NOLA
  4. Back To Top    #24
    Dec 2010
    San Diego, CA
    1,137
    And don't add all the cya at once - since you could still have 10-15 when the test shows 0 put in half of what the pool calc recommends and wait a week and retest. Given that to need to get shocking to clear the pool and that will involve backflushing, it may be worth the cost of liquid CYA as you don't have to Wai a week for it to full dissolve and show up on the CYA test. Just a thought.
  5. Back To Top    #25
    Dec 2010
    San Diego, CA
    1,137
    I just reread your earlier posts and saw they had you drain for total dissolved solids . Do you know what your CYA was at that time? Which pool store are you going to? I skip leslies and go to Coral Pool Supply on Convoy; don't know if that's close for you. Thy use strips for the basic tests but they're usually pretty close to the results I get with my own testing. They do CYA with the turbidity test and we've matched well on that. I even took the 50ppm standRd that tftest kits sells and they were spot on.
    Once we know your cya level we'll be able to get you going.
  6. Back To Top    #26
    Quote Originally Posted by carlscan26
    That's why I said 30ppm. If it raised it to 40-45 it wouldn't be a deal killer and he will most likely loose some to back washing anyway. It sounds like he will be backwashing a few times a day at first. Liquid cya would be fine if it is available where he lives. I have never seen it here.
    1 1/2 HP Challenger
    Located in NOLA
  7. Back To Top    #27
    Dec 2010
    San Diego, CA
    1,137
    Leslies carries it here in San Diego. I've seen it at the mom and pop shop I go to also.
  8. Back To Top    #28
    don't add anymore what? conditioner? when should I add chlorine?
    23,700 in-ground gunite SWG pool. Aquapure 1400 - Jandy valves and controls. DE Filter.
  9. Back To Top    #29
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    Don't add any more conditioner/stabilizer/cya (all the same thing). Add chlorine now. If you've been using chlorine tabs, your CYA most likely isn't 0. If they are using the strips, the lowest level is 0-30 so it could be higher than 0.
    In a 10,000 gal pool, one gallon of chlorine will raise your FC approx 6ppm. (By extension, a 15,000 gal pool will raise FC to 4ppm).
    So once you input your pool info, it'll help us and you figure out chemical amounts.
    BTW, did you in fact order a test kit?
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
  10. Back To Top    #30
    So how to get Calcium hardness to under 150? When to start adding chlorine?
  11. Back To Top    #31
    ignore last post, just refreshed screen
  12. Back To Top    #32
    how much is 2 ppm chlorine? sorry, novice.
  13. Back To Top    #33
    went to Tru Blu in Poway
  14. Back To Top    #34
    Quote Originally Posted by geopool
    Geo, the first you need to do before you post again is go to the user control panel(UCP) and create a signature and add basic info about your pool, how many gallons, what kind of filter and what size pump as best you can. There is a button at the top left The sig will show up everytime you post. You see it at the bottom of everyones post. Nobody can tell you how much anything to put in your pool unless they know how much water the pool holds. You are going to have to learn to use the pool calculator at poolcalculator.com You enter you pool info and tell it what you want to do and it tells you how much to add. We will do it and tell you what to add and you can do it as well to learn. It is very easy. The pool calculator is going to be your friend in the shocking process.
    Next answer this question. Do you have a test kit in hand? If not what is the status of getting one? Is it on the way or what? If you have it do a full set of tests and post the results here.
    If the kit is on the way we can start dumping some chlorine in to get things started but that is about all we can do is get a start without it.
    1 1/2 HP Challenger
    Located in NOLA
