Results 1 to 9 of 9
Thread: Strainer Basket Lid Blows Off When Turning Off Filter Pump
    Hey guys.
    When I turn off my filter pump, I get a backflow of water that blows my strainer basket lid off. Any ideas? Any help would be appreciated.
    Thanks.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Strainer Basket Lid Blows Off When Turning Off Filter Pu
    Install a check valve?
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Check for air in the filter. If there is a bleed valve at the top of the filter tank, open it and let the air bleed until it is all gone. If there is no bleed valve, you may unscrew the gauge and let the air out.
    Trapped air will compress when the system pressurizes, then when the pump stops, it pushes water back out.
    22,544
    Look for a suction side leak. Air is getting into the system and cuasing the basket to be pushed out when the pump stops. It's a pretty common to have a suction side leak. Check the skimmer and weir, check the pump basket lid and drain plug(s).
    30,414
    Yeah, you are pulling air into the system and, as a result, pressurizing your filter. Once the pump stops, the pressurized air in the filter pushes, the water back through the system and pops up your strainer basket.
    Find that air leak on the suction side and the issue will be solved.
    It looks like there might be a leak right at the pump assy.
    I have small water leak at the pipe that comes out of the top of the Hayward Super II. Would that be it or is it more of a seal issue with the pump itself?
    22,544
    The leak you're looking for is on the suction side of the pump. A discharge leak won't cause the problem you're having.
    30,414
    +1
