Thread: Using Chlorine to boost (Trichlor)
    Northern VA
    Do I understand from a posting (which I can't find now) that you can use granular chlorine to boost FC even if you are using a SWG?
    15 x 30 gunite pool with Riverflow Professional 12miles per hour flow (10HP silent ABB pump) to make the entire pool flow - Pentair Intellitouch i10 - Heat pump AquaComfort 110 - Raypak 399k Digital Gas Heater - Pool Pilot Digital SC-48 - Pentair FNS Plus 60 - Polaris 3900 Sport Cleaner on booster pump
    2 x Pentair Intelliflo pumps - one for filter (VF) and second for Venturi Pool Jets (VS) and Jandy 6 set deckjets - Pentair PG2000 Fiberoptic lighting - Automatic PoolCover (Brown) by Pool Cover Specialists
    Winter Pool Bubble by Ameri-Dome
    Yes, you can still add extra chlorine from other sources even if you are using a SWG. Keep in mind that granular chlorine typically also has either CYA or CH in it and adding too much of either of those will cause problems in the long run. The best source of chlorine other than a SWG is liquid chlorine, also known as common household bleach. It doesn't add anything that you don't want in the pool.
