Thread: Intelliflo and Suction side cleaner questions
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    I am looking at replacing my 1 HP Whisperflo with an IF VF.
    With my current setup, I have to crack the skimmer line about 2/3 closed to run the suction line on a Barracuda G4 cleaner.
    Will the IF make it where I don't have to close the skimmer as much, or not at all?
    I'm hoping I can open the skimmer line more.
    If so, can I set it up to clean with the skimmer partially closed. Then run it low speed to skim, then kick it up on a schedule to clean and not have to change the Jandy valves?
    14x30 PebbleTec(Caribbean Blue) 12,000 Gals BORAX
    Pentair IntelliFlo <<>> Pentair FNS Plus DE
    Pentair 5G Intellibrite w/Intellibrite Controller
    ROME Solarium 125 Heat Pump
    Kreepy Krauly Classic <<>> Pentair 320 Feeder
    South Central NJ
    3,192
    Re: Intelliflo and Suction side cleaner questions
    A lot depends on the head loss for each line and each line's size. It should be ok in most situations as long as you aren't using the SVRS model.
    Scott
    Owner of - PoolGuyNJ LLC
