Thread: Leaf stains at bottom of inground pool
    Hurrican Irene left me with pounds and pounds of leaves in the bottom of my vinyl liner pool (25k gal). It has taken days to get it all up. And now, particularly in 1 spot, I have a 6' (yes - foot) brown stain where the leaves had been sitting.
    Please tell me that I can get this off. Will chlorine slowly clean it up?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Leaf stains at bottom of inground pool
    Yes, chlorine will clear up organic stains. You can shock the pool or just increase your FC levels to the high FC for your recommended levels. It may take some time, but it will clear.
    You're done SLAMing when:
