Thread: Is my PH low or high?
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Hi all,
    My phenol red test results are orange. The color guide shows colors yellow and then into purplish/pink shades. So is my reading above the pink, or below the yellow? I have a tf-100 test kit on the way, but in the meantime I'd like to know if it's high or low. Thanks.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Is my PH low or high?
    the colors going from low pH to high pH are yellow 6.8 and lower, yellow orange 7.0 , orange 7.2, orange red 7.4-7.5, red 7.6-7.8, red violet 8.0 , violet 8.2 and higher
    If the color is orange red to red with no pink or violet you are golden.
    Based on these colors, your pH sounds like it is about 7.2.
    You're done SLAMing when:
    22,542
    Add an extra drop of phenol red to the sample and see what that looks like.
    Jul 2011
    844
    Why are there only yellows, pinks and purples on my color guide if orange is 7.2? I'm not at home now but 7.2 on my color guide is a shade of pink/purple. Certainly not orange.
    An extra drop and it stays orange. Maybe a LITTLE darker orange.
    Here's a link to a poor quality picture with a color guide like mine. Look at the color guide on the right of the test kit and you'll see that there are no orange markers.
    http://www.lifeguardequipmentandapparel ... estkit.htm
    Bestway SWG
    22,542
    I was thinking you had the K-1000 kit. It's colors are a little different and that's what the colors Butterfly posted are for.
    I'd say run a sample to the local pool testing place and see what they say it is. pH is one thing they usually get pretty close on.
    Jul 2011
    844
    Ok...thanks guys.
    Bestway SWG
