Thread: Cloudy water on adding sodium carbonate
    Aug 2011
    Oglethorpe, GA
    15
    Finally had my pool water almost perfect, then wanted to adjust the pH up a bit, so added some soda ash...the water instantly became cloudy. Here's the chemistry:
    FC 2.5
    CC 0
    pH 7.2
    TA 80
    CH 300
    CYA 55
    Salt 3200 ppm
    Added about 2 pounds soda ash, and water became instantly cloudy. I suspect this is just calcium precipitate, but wanted to know 1) if this is the case, 2) what can I do to keep this from happening again, and 3) is there a way to clear it up quickly or do I just have to let it run its course.
    In-ground vinyl 16x32, 17,500 gallons
    Sand filter, CircuPool RJ30 chlorine generator
    Re: Cloudy water on adding sodium carbonate
    Soda ash will cloud the pool for a little while. With the pH at 7.2, TA at 80 ppm, and a salt system, you should just wait for the pH to rise on its own. You can aerate to raise the pH if necessary. Give the water overnight to clear.
    Support the site
