Thread: Proper Salt setting & CYA application
    Jun 2011
    New Smyrna Beach, FL
    31
    Ok I have a Aqua Rite Electronic Chlorine Generator / T-Cell-15. The manual says the salt level should be between 2700 and 3400. The question is with a spread of 700 is the optimum 3050? If so the pool school recommends "200 to 400 above recommended". So If the optimum is 3050 should I bring my pool up to 3250?
    Question 2: I have read various ways to apply CYA into a pool. Is there a consensus here to the best and proper way to apply CYA into the pool?
    1: 10,000 gals in the ground plaster, Hayward pump SP2715X20 2hp
    2: Aqua Rite Electronic Chlorine Generator / T-Cell-15, Hayward Pro-Grid DE Filter Model DE3620
    3: AquaCal Heat Pump, Astrlite SP0580S Under Water Light
    4: Port PolarisCaretaker, TFTestKit-100
    Re: Proper Salt setting & CYA application
    I think you would push to the high side of the salt level since splash out and backwashing will lead to adding fill water that will dilute the salt level in the pool. If you get enough rain to overflow the pool salt level will go down. Most of the things you expect to add to this pool do not add salt, per the Pool Calculator.
    For CYA, we prefer to add the measured amount to a sock or knee-hi stocking and tie it so that it hangs in front of a return and the sock is buffeted by the flow. You won't lose it to backwashing the filter that way and you will know for sure when it is all dissolved. Don't bother to test for CYA until at least a week after the addition, just assume it is there about 24 hours or after it is dissolved.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    The sock method is by far the most convenient and verifiable method. When the CYA in the sock is gone, you know it's in the pool and not just sitting in the filter undissolved.
    Squish the sock frequently. Hourly or sooner. Keep squishing it till it's gone from the sock. If you have HTH brand CYA, it's very soluble and you should be able to get it all squished out and dissolved in just a few hours.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    When It drops below 3000ppm I add another bag of salt.
    10,800 gallons Gunite/Plaster
    Hayward 244t 24" Sand Filter with Zeo
    1 1/2 HP Challenger
    Digital Pool Pilot DIG-220 SC-48
    Located in NOLA
